QG18DE injectors on CGA3DE
Hi everybody,
this is the first post I write on MSC, so pleased to meet you! I'm from Italy and I have a K11 1.4 (CGA3).
I bought 4 fuel injectors of a Primera QG18DE that I want to install on my Micra.
I chose these because (I know many installed GA16 ones, but they're Hitachi, mines are Bosch) they have the same shape, resistance and type but a bigger flow.
Someone did this swap? They fit on CGA3 and work? Any advice for the operation?
Many thanks.
Bye
Sent from my SM-G925F using Micra Sports Club mobile app
frank
Thanks,
but, even searching on msc I couldn't understand how fit it in my fuel rail: mine is the coilpack one so there is no adapter, it's just plugged in(in some way). May I have to change the fuel rail with a pre-facelift one (is it possible?) or can I do in a different way?
frank
Thanks,
you can remove the hairclip and then remove the smaller O ring, then the fuel will flow freely through the reg.
then fit your reg downstream
