Product Porfolio
OP
OP
richmicratwista
richmicratwista
Direct Detailing UK
Direct Detailing UK SLICKCOAT Tyre Gel
Slick Coat is designed to be a quick, no fuss dressing that wont stain, run or turn tyres brown.
Directions For Use
Apply to sidewall using tyre dressing applicator or brush to leave a slick even gloss coat.
500ml
OP
OP
richmicratwista
richmicratwista
Direct Detailing UK
Direct Detailing Uk Speed Detailing Spray 500ml
Designed as a sprayable carnauba wax with gloss enhancing polymers, this is the ultimate quick detailer!
Can be used to prolong wax finishes or as a quick detailer for a fast solution to a glossy finish.
Directions for use
Spray sparingly directly onto surface and buff with a microfibre cloth. Buff with a 2nd dry cloth if required. Use dry for speedy touch ups or wet after washing your car for that just waxed look.
OP
OP
richmicratwista
richmicratwista
Direct Detailing UK
Direct Detailing UK Carnauba Wax 70g
With its high T1 quality carnauba wax content, excellence offers a high quality, durable finish. It's excellent water beading behaviour coupled with UV and acid rain protection ensures your vehicle is protected irrespective of the environment. Totally abrasive free, this is the ultimate last stage protection.
Directions for use
Apply a small amount of product to an applicator and work a very thin layer onto the paintwork. Allow to haze then buff with a plush microfibre.
OP
OP
richmicratwista
richmicratwista
Direct Detailing UK
Direct Detailing UK Glass Sealant
An ultra transparent coating that will bond to all of your vehicles external glass surfaces. Its super hydrophobic properties ensure improved vision and safety. Windows stay cleaner for longer and in some cases you may find using your windscreen wipers unnecessary! Stage 2 of the window sealing system.
Directions For Use
Ensure glass is completely clean and dry (We recommend using Direct Detailing UK Pure glass cleaner). Apply evenly to windows using a microfibre applicator and leave to haze for 10 minutes. Buff with a soft cloth until residue has disappeared.
100ml
