Problem
Right lads, first time I started a thread on the app lol. I have a problem where the main fuse was blown, I got that sorted and realised I had a dodgy radio. It must not have been grounded properly so took it out as it was blowing the rear light fuse. But now I have a problem where my dials and gauges aren't working, also the interior light. I've checked every fuse in the car and they're all good. Any ideas?
If fuses are fine double check the earth (had that problem poor earth on stereo blowing everything else) then check your connections haven't come loose
or if your bulbs have gone, if the lights stop working again ;)
Yeah double checked all fuses, I now have the CD player out as it wasn't earthing properly, tried putting it back in but it gas no power now changed the fuse still nothing, so the radio, interior light and gauges don't work, also the clock doesn't keep it memory?
dont know if its of any use to you but in my L reg micra k11 i ran a Earth for the radio to the clutch pedal housing seems to have done the job well with little effort.
