Problem with Windscreen water jets.
Today I thought my windscreen wash was empty as my jets werent pumping anything out. So i filled my tank and then tried the jets and they seemed to work with my bonnet up (see video 1) but when i put my bonnet down it then would only trickle out (see video 2). Any one know why it would be doing this?
Cheers
Vid 1
Vid 2
My drivers side tends to trickle, I blew the pipes through and changed for new ones, didn't help, but recently if I hit the wash to prime it I get a good jet up the windscreen second time. It is as if the water is draining from the pipes when not in use. Stumped me for a while but maybe just age related
the pump system is pretty simple, if the pump is working fine then from bottle to jets is just plain plastic tube. if the jets are squirting with the bonnet up then the only difference is the action of closing the bonnet; it would suggest that closing the bonnet is squashing the plastic tube at some point and restricting the flow.
the pumps themselves can suffer with moisture ingress, however this shows by the wipers coming on of their own accord. if you end up stripping it down to the pump level it is worth putting a smear of silicone around the pump joint irrespective of whether it is playing up or not. if it is then heat up the pump with a hot air gun for a while to dry it out first, but put decent quality silicone around the joint just as a matter of course. if you are that far in anyway you may aswell just do it as a precautionary detail because you have to take the headlight out, take off the wheel then partially take off the arch liner.
anyhoo, i digress, if you don't need to get to the pump then i wouldn't bother until you do need to.
going back to your original issue, unless there is a crack in the pipe, which then gets closed up when you open the bonnet (which i find almost implausable, but not completely so) then the only thing it can be is restriction of the pipe in some way. if there were dirt floating around the pipe then the pump pressure would overcome the gravity issue and it would still block up.
so if it were me, i'd be looking for the pipe being squeezed by the bonnet being closed.
The videos aren't working for me
If it works while open, but not while closed, is it possible the pipe is being crushed or kinked by the bonnet at some place?
sorry to copy you, i didn't notice your comment until after i posted, however, i concur. you can have the positive good vibes from this, i just ramble on too much...
