Power steering fault - Can you fix?
Hello
I browsed already Internet about this issue and I could not find answer to the question, which is: Is it possible to fix yourself power steering temporarily to work in order to pass the inspection?
Is there consumer available device to get this "error code" cleared?
just about all error codes can be removed temporarily there was an issue with these units where as the unit was not broken but threw up the error code when dampness got into it. try ebay for code reader. I also think that this has been coverd in the past
Loss of powersteering should not affect the inspection. The little car is just somewhat heavier to maneuver. I guess you have already discovered that there is no need for extensive repair/change of parts. Here in Norway the Nissan Garages try to get 1000 - 1200£ for repairing the ps. But it is normally just a programming thing that can be fixed in 5 minutes.
