Porks bike carbs and boost project
pork
pork
You wouldn't want it mate, I crushed of a few pipes and blanked some other idle stuff, just basically a butterfly valve and that's it :)
pork
pork
Mounted
pork
pork
Eerrr, yeah I guess, had last can a few months, depends on how big the job is, how high you set the regulator....I jus whack mine on full
and TIG its only argon, on MIG the misture with 2 gas (argon+co2) because argon are more expensive, this is what we usually use where I work , now do not know what percentage of each in the bottle
Iv done a bit of DC stick welding lately. its a breeze, better than MIG imo unless you are doing <1mm. That SS stuff looks very nice Frank, did you get any warping of the flanges?
frank
arc penetrates better imo ed :) and yes the flanges did curl their toes a bit as you can see, but luckily its in the right direction for squashing the gasket when the nuts are pulled down
neil will be doing some stainless welding on his kit-form mani too (when i can find his postal addy :) )
Almost impossible to stop SS warping unless you bolt it down to a jig iv found.
pork
pork
Got mani pipes through today, cheers frank!
Got stainless plate to make up some flanges
Not sure when I'm putting it all together as I'm moving house within next 2 weeks (at last!)
It's a 'do-er up-er' lol
So ginna take a while
pork
pork
Not yet
Only just settling in to new house, needs a lot of work to have it nice for family
If i do the house right, il be in the good books with the misses
Really want a pao!
pork
pork
Had a spare hour or so for first time in ages
So drilled holes into stainless plate ready to be mounted to the manifold pipes
And finished of the throttle body inlet
pork
pork
Cheers,
Still havnt got a car to put it all back into tho
If any cheap k10's going, and condition, give us s shout
pork
pork
I wish mate, yours is super clean
I literally hav no money (house consumes all)
Lucky I still have all running gear from last car.....so really only need a rolling shell
pork
pork
Had a start on welding the manifold up,
I leafy the flanges quite big so it didn't warp, il grind them down later
Never welded stainless before, not toooo bad
Quick look of how things will look.....will be putting charge cooler between charger and inlet
pork
pork
I thought you were selling up for a flat dude
I was selling my flat for a house
Now have house, and done all major renovations, (kitchen, bathroom, phoebes room)
I've got a man shed now too :)
No one bought all my engine stuff, so all I need is a rolling shell and bolt all this stuff that's sitting here doing nothing in
Quick question pork, the ignition panel you had, did you get it fitted, (on tapatalk so can't search :( ) as I'm thinking of getting one for mine
Sent from my slutty secretary as I'm tied up In The fungeon
pork
pork
Nah, didn't bother in the end, used all the switches and relays for other bits
Damn I'm thinking of doing it to my k10 but have no idea what wires go where lmao
