pollyp
Last night after a car meet, kassandra's clutch pedal suddenly dropped to the floor & broke down whilst driving home
pedal felt light, couldn't select gear and reverse kept crunching, so the clutch definately ain't disengaging.
I managed to tighten the cable all the way to make it barely work, but she squealed & shuddered badly so I nursed her home using minimal clutch
drained the dark gearbox oil
usual amount of debris on the plug
removed the gearbox
ah crap, so I guess the clutch fork had enough of the strain from the heavy pressure plate after 10yr of use/abuse and snapped off
I believe the cause of all this is the old grease I put along the release bearing/input shaft collar, which is now a very sticky dry goop mixed with clutch dust. I've had this issue all the time
This dramatically increases friction making it harder for the release bearing to slide along.
It explains why the clutch felt harder & harder in the past year, even after I re-oiled the cable several times.
Since I've already reinforced the pedal box, cable ends & cable mounts, the next weakest link to fail from all the stress are the thin clutch forks
After it broke and I tightened the cable really hard to get her home, it bent the release bearing plastic collar at a wonky angle which is why it squealed & shuddered.
the clutch itself looks fine
gearbox side of the plate wears more than the flywheel side
according to my records, it still has approx 21,000m or 2.5yrs of life remaining.
I best look for a replacement
swapped over to a spare gearbox to save time & make mondays trackday
removed the gearbox
