PollyMobiles Rebuild
OP
OP
pollyp
pollyp
simon with the silver R33 brought some spare oem R33 headlights with replace his current odd mascara looking lights but it's been damaged during postage and wondered if I could fix the smashed bits
the drivers side was mostly ok but had a small crack in the lens cover and the indicator reflector was melted and fitted with an LED bulb so will need replacing
the passenger side had a badly smashed back end
the 90deg adjuster was sticky so I cleaned that up
so the plan is for simon to remove his current headlights, we heat up & remove the lens from both sets, then we reassemble it with all the best bits
OP
OP
pollyp
pollyp
there's a faint knock every time I use the wipers and checked it's wasn't the wiper blades
looking inside I found the linkage was hitting the side of this rusted panel, so a few hammer blows solved that 😁
I also get alot of smelly clutch dust coming through the vents due to the raised bonnet & exposed bell housing
so I mocked up this card shroud to cover the air inlet and it worked, just need to make it properly next time
OP
OP
pollyp
pollyp
the night before a car show, I cleaned n polished the car but then got carried away with improving the air filter mount & fuel lines.
I removed the carbon canistor to allow more space to mount the intake pipe
roughly & quickly welded this bracket to where the carbon canistor was to support the pipe
abit straighter to the straut brace & less rattling
OP
OP
pollyp
pollyp
2020-01-19 Wynyard Hall Cars & Coffee
met luke at the nearby services for breakfast
it was a long queue going into a cold crispy & muddy wynyard hall
soo many ppl got stuck on this loose muddy field
parked, cleaned & wondered around
a cool sp1 lotus esprit from the spy who loved me :cool:
this steampunk singer sport made by an inventor was stunning. more you look at it, more details you see 😎👌
OP
OP
pollyp
pollyp
the grass was now all soggy & muddy after the sun has melted the morning frost so the cars have sunk abit and more ppl were spinning muddy wheels getting out compared to this morning. thankfully my car was light and parked close to the tarmac.
so much for cleaning the cars beforehand 🙄
OP
OP
pollyp
pollyp
Luke gave me these spare blue H4 bulbs found in the garage
comparing my current Halfords Extreme Brilliance (left) to the spare blue bulbs (right)
the extreme brilliance (left) has the normal amber temperature but has a brighter broad beam whereas the blue bulbs (right) is only slightly cooler but abit dull and less broad
went for a drive and eww the blue bulbs is ridiculously dim/bleak/underpowered and the colour just tints the scenery all flat so I struggle to distinguish road features. absolute rubbish.
I even tried sanding the blue coating off to see if it was absorbing the light power and I found the brightness of the bare filament itself was actually alot weaker than the extreme brilliance, explains why it's soo dim.
in the bin they go 🙄 😄
checking the brake pads, the OEM GTIR front pads are wearing roughly the same rate as the black diamonds under normal street driving
the rear OEM pads are now worn out and need replacing soon. the inner pads are wearing faster than the outer pads, maybe the piston or handbrake mechanism is sticking slightly?
welded this power steering hose/HP line block to the strut brace to stop it rattling
engine compression is at an equal 11bars
OP
OP
pollyp
pollyp
sunday car meet. most of the rattle's gone after fixing that PAS mount but then another rattle appeared from deep in the dashboard/bulkhead :rolleyes:
the rattle was soo annoying, resonating at 1.4k & 2.4k rpm sounding like a loose screw/washer in the dash and not from the engine bay.
I stopped by a quiet roadside and spent hours holding the revs at 1.4k, stripping the dash apart looking everywhere for that sound but couldn't locate or reach it cos it's deep in the bulkhead around the heat matrix.
but then on the way home I turned the heater knobs and JEEZUZ behold it was the Friggin heater diverter vanes in the center dashboard which was rattling around when it's set to Face & Feet 😫🤬🙄
turned it to Windscreen or Face and it's quiet now phew! 😇
OP
OP
pollyp
pollyp
leaving home for work this morning I soon noticed the power steering getting abit heavier and then a faint whine of the PAS pump and a slight smell, ohohhh
pulled over to check around and saw the PAS cooler hose that I fitted as a quick fix has slipped off and drained all the fluids 🤬🙄
so I had to nurse it home & take the other car
home after work, I removed the front end, found my brake flaring kit has the right size for flaring the15mm pipes, and cleaned up all the oily mess
also used some OEM rubber hose from a TB to form the U bend. the orange garden hose thing was too rigid and didn't clamp well
reassembled, bled it with new ATF fluid and yea it's all working fine again 😎
OP
OP
pollyp
pollyp
this morning kassandra refused to indicate left :unsure: the hazards work and can indicate right.
checking the storks after work, I found the connector wasn't fully plugged in 🤦‍♂️😄
brought a new set of rear discs & pads from work for £58
removed the crusty old brakes
discs had a deep groove worn from 7mm down to 6.44mm
new pads feature a wear groove
installed and went for a blast around town
dunno if it's the included shims or if there's air in the system after I had to bleed it (piston dust boot slipped out) or if these pads need a few hundred miles to bed/bite but it feels a tiny bit spongy near the bite-point and doesn't brake as hard initially.
pushing the pedal further would obviously feel firmer & brake hard as normal.
guess it needs more miles.
OP
OP
pollyp
pollyp
the sidelights had this awful amber colour compared to my headlights and LED lighting so I got these LED 501 bulbs for £6.50
and what a difference between the amber normal bulbs (left) vs LED bulbs (right)
looks all gr8 now 😎
OP
OP
pollyp
pollyp
the standard black paint on the manifold has burnt off leaving a white ash
so I wirebrushed it off and resprayed it with screwfix VHT paint rated for 600deg. after curing & heating it up, it's now staying intact although a tiny section has peeled off perhaps it didn't bond properly
time to get rid of the 4yr old toyo T1Rs which are all worn, hard, no traction and really noisy
got a local garage to fit my new Falken ZE310s.
one tiny annoyance is they didn't align the yellow dots to the tyre valves and one of the wheel weights is double stacked 🙄
painted em
noting that these are fresh tyres so they'll have a slippery release agent on the treads for afew miles.
Initial impression of going from really old worn T1Rs into fresh ZE310s:
- a lot quieter, commuting down the carriageway the Toyos had a deafening ROAR whereas these new thicker Falkens are half as loud 😎
- sharp steering response
- good turn-in cornering grip but slippery & nervous under sustained fast corners due to the release agent. improving as I drive more miles.
I'll need to reconfigure what pressure to run these in future cos I'm currently at 3bars/42psi which will affect all these factors above.
want to improve the rough air intake mount so I decided to weld this rigid square tube frame to a T-clamp which then holds onto the intake pipe.
the T-clamp was bigger than the alloy tube but a silicone coupler was just the right size, plus it helps dampen vibrations too
the microphones on the action camera and smart phone ain't good so I tried out this dedicated Sony ICD-SX733 voice recorder.
it has internal stereo mic pickups but it wasn't good, lacked clarity, lots of reverb and caught alot of vibrations, bumps, etc
didn't have a microphone available but then I discovered I could use little earphones as microphones. tested em on the roof, dash and taped to the seat and although they function, it's really quiet & lacks clarity, muddy. the sound quality is similar to the cheap encased goodmans action camera whereas my Drift X170 had a better crisp sound quality.
so I brought this recommended Sony ECM-CS10 stereo microphone online, coming from japan for £39
another cold night at tdays car meet
OP
OP
pollyp
pollyp
Comparing Toyo T1R vs Falken ZE310 Contact Patch
To see how the pressure & construction affects the contact patch between the two tyres, I sat the wheels on a flat slab and measured the contact size with 2 sheets of paper under various pressures
the lateral tread doesn't change much with pressure
but the longitudinal length of the tread varies alot between the two tyres throughout the range.
the tread begins to flatten out below 2 bars
the T1R is a softer construction and shows a much larger contact patch per PSI/Bar than the Falkens.
I used to run the T1R at 3 bars in order to provide enough sidewall stiffness.
If I run these Falkens at 3 bars, the steering response is alot sharper than the Toyos but reduces lateral grip.
I now run them at the factory recommended 2.5/2.2 bars which gives roughly the same contact patch as my old Toyo, much better lateral grip and a bit quieter but the dead-centre steering response is now similar to Toyos.
OP
OP
pollyp
pollyp
my old Halfords "100% brighter" H4 bulbs are abit poor in the pitch black country roads so a few ppl recommended getting these Osram Night Breaker Laser (£20 on ebay, half the price of halfrauds)
the halfords have a blue half-tinted dipped beam and clear high-beam whereas the Osrams are the opposite
conparing the halfords bulb in Left vs osram bulbs in Right.
they both have exactly the same intensity amber dipped beam
but on high-beam you can see the Osram has a white long-distance center core surrounded by a darker-cooler blue on the outside
here's with both osram bulbs Dipped & Full beams
testing it in the dark country roads, we see the broad & bright amber dipped beam lighting up the nearby road
when going full beam, the clear inner core shines far into the horizon where the eye is focusing meanwhile the blue outer tint slightly darkens the nearby ground so the peripheral view is not as glaring or distracting.
overall it works great 😎 👌
OP
OP
pollyp
pollyp
woops I forgotten to empty my catch can for the past 6 months and it's fully brimmed 😬😁
stuck this shield on the bonnet to stop clutch dust getting into the cabin intake
Max Plester has a pair of pre-face wings for free and mine are getting pretty rotten nowadays so I said I'll come collect em.
although he's 4.5hrs away down Newbury and there's gonna be a bad storm on sunday 😬
in preparation for the long haul, since micras don't have cruise control, I made this simple crude hand control so that when my right or left leg is tired of pressing the throttle & cramping, I use my right hand instead.
OP
OP
pollyp
pollyp
driving down to Newbury tday while storm Ciara hit the UK.
struggling through all that rain & spray & gale force head wind, kassandra was instantly filthy and wasn't happy.
she struggled to accelerate and her AFR was irratic, sometimes leaning out during high load, sometimes just reading 9-10afr.
there was also an annoying loud rattle for afew secs whenever I drive through some deep puddles. tday the rattle got worse so I checked it over and turns out to be a loose nut from where I bolted the exhaust silencer directly onto the chassis. simply tighten it up ☺
arriving at Max to collect the spare battered wings. I also took out & checked the wideband cos it simply kept reading too rich, nope it looks clear. once I let the car rest for a moment it reads fine again. there's no error code but I guess it's time to replace that sensor
after all that head wind & rain, she did a surprisingly rubbish 30-35mpg
after 4pm the storm had passed and it was a calm drive back home at a light 60mph in the dark. 6 boring hrs later I reached home and she did 46mpg. was ok but expected more after driving that carefully, needs more refining of the mapping & alignment
£80 of fuel for a rare pair of battered wings :p
they're gonna need a good panel beating to straighten up in future but at least they're not rusty
replaced the wideband sensor and it reads alot better
replaced the old 60-70mm reducer elbow & 60mm intake pipe with a full 70mm elbow & 70mm stainless pipe for better flow :cool:
Quote; “calm drive back home at a light 60mph in the dark. 6 boring hrs later I reached home and she did 46mpg. Was ok but expected more”
I recently did 63 mpg in my 22 year old 1300cc K11 over a 320 mile round trip @ 55/60 mph on mixed M way & A roads.
It’s on 46 K now & all original unmolested just as Nissan design engineers set it up to be put together right first time every time at Nissan Sunderland all those years ago.
It only gets simple basic DIY service maintenance by me every two years & passes MOTs year on year with no issues, snags or advisories.
Hands off works good enough for me. How could I do it better?
Happy days, happy K11 motoring days, long may they continue. ;)
OP
OP
pollyp
pollyp
63mpg is brilliant, I wish mine could do that during long cruises.
actually I just found out tonight that I've been using the wrong map in Nistune for running the standard N/A setup, which may explain why the AFR was all over the place and the poor mpg.
OP
OP
pollyp
pollyp
the new Sony ECM-CS10 stereo microphone arrived
tested it on my Sony digital recorder and it records the cars sound soo much better, clear, and sensitive enough 😎
the wheels need aligning after replacing tyres but the rear trailing arms were seized so I need to overhaul them first before I can adjust the rear axle
wirebrushed the whiteline arms
the old handbrake cables are terribly worn/damaged from being ziptied to the trailing arms for the past 10yrs cos the whiteline arms didn't come with the required mount brackets, so I'll be welding a new mount next
there was a ton of bubbly rust on this rear bumper beam but thankfully it's mostly still solid.
yet more rust repair to do at the rear-end and CBA tonight tbh 🙄
I also just realised tday whilst playing with nistune that since I've been running the N/A setup from last year,
I've been using the wrong N/A map, which could explain the poor mpg & AFR & power.
Nistune has a library of original maps (ROM-Packs) from the various versions of micra ECU's.
- my original 1998 SLX cg13 NATS ECU had a serial code "1U203"
- last year during the ECU glitch issue I replaced it with a later facelift ECU with code "74B61", which has various slight tweaks to the map
- but I soon realised that I've actually been using the map for a "74B01", which has very different parameters, map scaling, injector size etc
so I'll soon be reverting back to the 1U203 map once she's running again
OP
OP
pollyp
pollyp
welded some mounts on the whiteline trailing arms for the new handbrake cable
painted
wirebrushed most of the rust off the rear bumper beam and the lower half is quite thin but mostly ok
looks like she's previously been reversed into a lamp post or something
a hammer fixed it 😁
painted
OP
OP
pollyp
pollyp
a local m8 Dillan said he had a preface bonnet I could have for free so I set off to newcastle to collect it.
turns out he no longer has a micra and couldn't sell the micra parts as fast as his storage rent was draining his wallet and just wants rid of it all asap so I could have anything there free 😁
I ended up coming home with a rust free bonnet, a Magnum bucket seat botched onto a micra subframe, clarke pro 90 welder, 5 door wind deflectors, A-pillar covers (to re-do my gauge pods), a heatgun, and spare indicator storks.
well worth the trip for a load of freebies 😁👌
this Magnum solid bucket seat is soo light and will be handy for trackdays. it was simply bracketed onto the micra subframe as shown 😄 so I'll obviously bin the micra frame and fabricate a custom seat frame for it
wind deflectors fits nicely, saves me from trying to make one from scratch
this clarke PRO 90 was is a poor state but after cleaning the rusty drive wheel, replace the tip & shroud, regrease the tensioner, fit the spool, gas & regulator, it all works fine again 👌 it's a really quiet machine cos it has no cooling fan like my 135TE Turbo
I noticed that it was leaking gas inbetween welding so I opened up the MIG gun
found out the pneumatic valve for the gas was simply abit sticky, some wd40 solved it
rear bumper painted ready to fit
OP
OP
pollyp
pollyp
while replacing the handbrake cables, this exhaust shield support bracket was bending and quite flimsy so I welded a sturdier version
new handbrake cable all fitted and it now works soo smoothly 😎 👌
one of the stiffer 5kg rear springs arrived. awaiting the other side and I've already got the 6kg front springs in garage
OP
OP
pollyp
pollyp
opened up & comparing the spare Clarke mig Pro 90 to my bigger Clarke mig 135TE turbo
they both have very similar layout configurations except the 135TE has a cooling fan, power cord coming out the front rather than the rear, different circuit board and thermal cut-off
OP
OP
pollyp
pollyp
both of my 10yr old BC coilovers are looking abit crusty and the cover has perished.
so it's time to freshen it up, replace the springs with a stiffer set of 6/5kg front/rear coils, and finally lengthen the lower control arm by 10mm to correct the camber and stop the tyres rubbing on the chassis at full lock
took abit longer than expected to strip only the right-hand apart due to rusty fasteners, espectially the big nylon locknut I used on the lower balljoint which was doing it's job and really really tight to get off
strut in good state, just need a good wirebrush
inner dust boot needs replacing. I'll also be looking for a 80mm x 300mm rubber bellow to cover the entire coilover against the elements
I've still got the other left side to do.
this job has just gotten abit harder & longer to finish 🙄
Same here with alignment just had it done and wanting to change out suspension/other items that may need renewing.
There are guides available for a basic alignment. That may work just not very accurate as these days its laser alignment.
Sent from my ASUS_T00P using Micra Sports Club mobile app
OP
OP
pollyp
pollyp
the lower lock ring securing the hub to the coilover threaded body is seized pretty tight and the original flimsy "one teeth" coilover spanner tool is simply gonna chew the lock ring up.
so I made this lock ring tool by cutting precise teeth slots inside a used brake disc to spread the load evenly across all the teeths
clamped the assembly on the vice, placed a long steel pole between the 2 bolts on the new lock ring tool and after a lot of brute force, it unscrewed off the lower hub
the rusty steel lock ring was still seized onto the threaded body 😤🙄🤔
after a tea break to calm down, I figured to lock two collers onto the new tool and clamped solid on a vice and then after a few persuasive hammering, the lock ring slowly loosened off thank god!
thinking of replacing it with an alloy version (hmm nope, BC has a ridiculous £7.70 postage totalling £23 for the tiny lock rings, and I've already ordered 2 seperate springs and a dust boot so I'm gonna leave it)
all stripped to be wirebrushed
assembled with the 6kg coils and helper springs
Yes I agree 63 mpg could be a new target for you to aim for & then surpass?
It is good enough for me in my 22 year old 1300cc K11 over a 320 mile round trip @ 55/60 mph on mixed M way & A roads using the defensive driving technique of simply avoiding throttle & brake driving.
Most of the credit is due to the Nissan design engineer’s original optimal economy tuned balanced set up of the K series Micra which still applies to my vehicle as nothing has been changed or fiddled about with, except routine service consumables such as tyres & brake pads/linings during 46K from new.
Happy days, happy K11 motoring days! :)
OP
OP
pollyp
pollyp
naa she's very far from reaching that 😄
she's set up more towards high performance & circuit handling at the expense of comfort & economy.
OP
OP
pollyp
pollyp
stripped apart & wirebrushed both the modded & spare lower arms in preparation for lengthening it
the lower spherical bearing has held up ok for the past year, packing it all with thick red rubber grease certainly helped preserve it better but it does have 1/2mm of play now and time to replace it
I found a crack developing on the drivers side arm 🤔 maybe the front poly bush was getting too sticky and bending the arm repeatedly till a crack from the edge lip propagated?
I'll drill, grind & weld the crack back together and also add an extra strip of steel along the front to reinforce it more
using a chop saw to maintain accurate consistant alignment, I chopped a straight 22mm section off the spare arms which'll be welded onto the modded arms to lengthen them
this mod will hopefully push the wheel hub outwards to restore the normal track-width, stop the tyres rubbing the chassis at full lock and allow the BC coilover top plate to adjust the camber beyond 1.5deg
OP
OP
pollyp
pollyp
arm pieces tacked into place
all welded up after hours of work, had to do several passes. gonna add another strip of steel across the front to reinforce it.
wish I had a TIG welder for better control
painted the coilover hub bracket
OP
OP
pollyp
pollyp
Bad news
This morning I woke up with a sore eye as though some grit is under my right eye lid.
Couldn't rub it away, it just got more inflamed, eye wash did nothing, was really annoying to blink & look at a certain angle with that sensation whilst driving.
Went to a local hospital after work to see nurse bout it.
She numbed and UV dyed the eye looking for debris scratches.
Unfortunately turns out that I have a tiny spec of metal stuck in the cornea over the iris area from grinding my welds briefly without goggles
She tried swabbing it but looks like the cornea skin has grown over it during sleep therefore creating the annoying 'bump'
Gave me antibacteria ointment but I'll have to visit another hospital's eye specialist at 8:30 before work to try remove it with a needle & magnifier
Guess Kassandra is on hold for now
Sent from my CLT-L29 using Micra Sports Club mobile app
Bad news
I've had similar, not the most enjoyable thing I've had to do, it's easier if it's off centre in the iris rather than the pupil as you don't have to watch the needle coming...
When I was a young electrical trainee technician I got a speck of metal swarth on my cornea sclera while hole cutting. Some years later I got arc eye just walking through a structural steel fabrication workshop.
In both cases, after medical attention I made a full recovery, as you will.
I quickly learned from these experiences that it is quicker, better & cheaper to apply appropriate H/S PPE precautions every time, to do it right first time, to do it once.
So much welding comes with long term health risks exposure to intense arc radiation, breathing flux & metal particles fumes PM 2.5. requires more than just a mask & goggles?
https://www.hse.gov.uk/welding/health-risks-welding.htm
Quote; “Fine particles (PM2.5) pose the greatest health risk”
https://www.google.com/search?client=firefox-b-d&q=pm+2.5+particles+health+risks
Probably much more injurious to long term health than smoking & is it really worth those known listed risks?
Get well soon.
OP
OP
pollyp
pollyp
Yeah it ain't pleasant, mine was at 7'clock offset the pupil. Was trying to concentrate hard at the incoming light but I can briefly see the nurse prodding the syringe needle at the cornea and my vision wobbles
OP
OP
pollyp
pollyp
Get well soon.
Ur right.
For many years I never had such serious injury so the moment of ignorance thinking I'll just quickly grind a section without goggles to save few sec of convenience and be OK...
Actually ended up punishing me now with visits to the hospital, a painful eye during work, afew quids worth of meds and most importantly losing at least a WEEK of progress on Kassandra honestly it's not worth the risk I learnt
OP
OP
pollyp
pollyp
So the nurse tday tried poking the flake of rust out with a needle but can only get some of it out cos its actually abit deep (probably made worse from all the rubbing)
So we had to reschedule the Fri for a specialist to dig abit deeper with more precision.
Once the numbing wore off at work tday, jeezuz! My eye was stinging like chopping onions and driving the van 1 eyed was insane and the eye was painfully sensitive to bright light, the super glaring low & rainy sun was agony
Hello.
I know what you are talking about.
I've had almost the same problem ( 2 thin metal pieces stuck inside the white part ).
Best whises Paul
Inviato dal mio SM-T585 utilizzando Tapatalk
Ur right.
Your visual distress reminds me of my once & only arc eye that was nearly forty years ago & had largely forgotten the pain intensity & stress. I do remember the extreme light sensitivity that I could not bear to see the brake lights of the vehicles in front on the way to the A & E at night. I could not stand daylight at all.
I did not have a clue what the problem was as I never did any welding. That ignorance changed when formally diagnosed with arc eye & hospitalised for a week at great expense to my employer sponsor in Saudi Arabia. Caused by simply walking through a steel fabrication workshop without appropriate PPE precautions to attend to a down shop overhead traveling crane electrical logic controls breakdown.
With benefit of hindsight I now consider it was due to the over excuberence of youth combined with a lack of experience ignorance at the time.
Get well soon.
