PollyMobiles Rebuild
Genuine Nissan or knock-off? If it's the latter, DON'T jack it up using the front jacking point or you'll turn it into a banana without additional reinforcement.
i got the Taiwan after market one and not had any problems jacking it up ,it's kinda thin but about the same as the original ,even welded ok with a arc welder when the mig broke, and surprised it held up without rusting it wasn't really sealed or painted except the welded.bits
sister was replacing her carpets so I grabbed the underfloor insulation she was gonna chuck away so I can insulate the micra again.
I first made a piece for the boot floor
View attachment 58992View attachment 58993View attachment 58994
those stick on sound deadening packs seems to work, I've got 10 I think on atm ,rear wheel well, n/s.inner.arch , rear quarter panels, inner sill, and some on the main floor and the car seems more.quiet, except the exhaust lol, but the road and rattles seem less , as originally I had some sound deadening cloth in the boot and 3 pieces of the stick on does the same / better?
OP
OP
pollyp
pollyp
Think I'll have to remove the dash to muffle the bulkhead where most of the noise comes from
Sent from my Nexus 7 using Micra Sports Club mobile app
... Have another recommended spot? I've already bent my sills a bit :oops:
the front floor rails, and put the axle stands under the rear wishbone mounts, under the rear coils of the rear axle or can jack on the towing eye, then axle stands in front of the trailing arms on the chassis legs , check your crewmember first cause of its rotten or or damaged, they can bend lol
SuperUno
Buy & Sell Member
how'd you recommend I reinforce it?
weld a few angled truss ribs inside the box section?
Maybe over kill on a non rally car. I used angle iron on the front faces and then flat iron to make a 'box' around the three faces of the box. Can get some pics at some point if you want. That then is braced to the chassis rails. It is the sump guard mount so is prone to a lot of force and abuse. But will very easily take whole weight of car on it.
OP
OP
pollyp
pollyp
as Jack mentioned above, I use my trolley jack under the lower control arm rear bushing and the rear axle beam and then place the axle stands on the front floor rails and in front of the lower trailing arm mount or on the axle beam
OP
OP
pollyp
pollyp
yeah sounds like a ton of overkill for her :D
think I'll leave it cos I'll never jack up from that point anyway and its extra work :p
OP
OP
pollyp
pollyp
welded up all the holes on the front panel so dirt/water can never get inside in the 1st place
chopped out these side sections for the intercooler plumbing
bent & welded back up
OP
OP
pollyp
pollyp
at work I measured a few concentric clutch slave cylinders to see if they'll fit my CG13 gearbox.
item #510 0225 10 fits over the 27mm diameter input shaft coller but the diaphram facing collar is abit too large.
but all of them are simply too long at 57-63mm compared to the 34mm long release bearing / input shaft collar.
the other easier more reliable option is the traditional external slave cylinder operating the clutch arm.
coupled with a remote master cylinder this seems to be the best way to 'test trial' if a hydraulic clutch suits the setup and can easily revert back to cable.
OP
OP
pollyp
pollyp
with a big spare roll of foam carpet underlay ready and afew sheets of rubber floor mats, lets begin stripping out the interior to prep & install the insulation
spotting a few little rust spots around the fan inlet, bulkhead rain channel
wondering whats inside this dimple cover?
ooh the angled foot well is hollow and allows access to the sway bar / rear bushing captive nuts
wirebrushing the rear floor pan and damn, more rust holes to fix
bent a new plates
tacked
welded
welded the boot hole
hammerite & painted
now I can finally begin laying the insulation tomorrow :cool:
OP
OP
pollyp
pollyp
interior stripped bare, the roof & floor panels resonate so much like a biscuit tin
the roof panel was barely attached to the cross beams with afew tiny dabs of sealant. fill the big gaps with sealant to reduce any panel movement
begin lining the rear arches with foam carpet underlay using spray contact adhesive. it's relatively easy to fit with the foam being quite stretchy & flexible to mould around the curves
painted it black & stuck some on the roof
the whole rear end is now insulated, looks cosy :D
insulated the front of the roof
OP
OP
pollyp
pollyp
assembled the dash
assembled the rear end and applied the rear floor mats
painted the parcel shelf black :cool:
interior all finished, insulated, painted black and looking awesome :cool::)
went for a test drive and Wow! what a huge difference :eek:
at idle the cabin is nicely muffled from the clicking engine bay and there's just the very low freq purr of the exhaust.
at low speed it's very luxuriously quiet, the clicky injectors and turbo spool up below 0psi are barely audiable, you just get this surge of torque.
once I accelerate with higher boost, then the spooling noise comes up but still very smoothly muffled with non of that clicky diesel sound of the injectors and the exhaust ain't as boomy loud any more.
and now when cruising along motorway, especially on that insanely loud rippling carriageway to work, that deafening tyre roar is halved and exhaust no longer drones / boom / resonate inside the cabin. it's soo comfy I can actually hear my stereo, hear my voice without screaming, no longer need to wear ear plugs :love::cool:
wish I did this so many yrs ago
Polly you are my Hero.
You know Cassandra better that your pockets.
Wow what a jobs. ..
Inviato dal mio SM-J500FN utilizzando Tapatalk
Wow! Just read your whole blog it's taken me over a year haha well worth it tho truly amazing work really inspiring :) only started reading it to see what gains could be achieved from fitting nistune but now I'm definitely fitting a turbo in the near future!
Sent from my SM-G901F using Tapatalk
OP
OP
pollyp
pollyp
:) thanks m8
glad the lengthy blog helped ya
OP
OP
pollyp
pollyp
briefly visited Jamie from 'LetsTorqueCars' to check out his recent micra purchase & to film more short videos
he brought this 1996 1L 5dr Shape as a daily runner and it's in fantastic state, only done 56k and paid just £550 :D
we videoed the car doing a few cheeky launches :p
OP
OP
pollyp
pollyp
with the video shoot & car meet out the way, it's time to replace that rusted front end before her MOT in Oct.
began stripping the front off
to my shock, it turns out that the old botched front panel wasn't even fully welded on!
it was only attached with a few bolts, pop rivets and little poop tack welds :eek:
removed the rotten old front panel :poop:
now you can see the turbo setup and the state of the chassis legs
so this is where the past owner had smashed the left side
test fitted the new panel but something's odd
the sides don't meet
when I bolt up one side, the other side is really misaligned
noticed the panel is assembled unevenly
chopped it into pieces to align the seperate bolt holes before it's welded back together
things getting abit serious when I use the rotary laser level to measure where exactly it's deformed wonky
so it turns out the reason for kasandras wonky bumper is cos the past impact had bent the LH chassis leg down by 3mm and the weak LH bumper mount by 10mm!
notice the RH bumper mount is square & reinforced inside whereas the LH mount is just an open square section easily skewed downwards
straightened up & reinforced the LH mount
this headlight stud broke off
made a permenant metal bracket
wasn't happy with the way this new cheap panel was slightly wonky-jigged so I drilled it all apart
so now I can easily tweak the positions of everything till all the gaps are equal before I weld it back into place :cool:
OP
OP
pollyp
pollyp
figured this mangled bit of flange where it was hit would be a waste of time to hammer into shape
so I chopped it out
and found these bits of the old seat rails had the same thickness plus the correct short edge to weld onto :cool:
wirebrushed & primed
welded up the new panel ready to grind em flat
OP
OP
pollyp
pollyp
I'll need to tweak the bonnet struts which are touching the chassis and affecting how far the bonnet closes
undercoated & painted the new panel & chassis
repaired this damaged section
also repaired this old thin mangled top corner
fitted the front end to make sure all the gaps are equal
tacked & welded into place
LH section
RH section
grinded the welds flat and painted
welded these tabs to hold the wings solid from the headlights
yayy for the 1st time she has a nice level head
soo exhausted but I'm at the final stages of putting it all back together, fix the downpipe, before it's due MOT on friday :cool:
OP
OP
pollyp
pollyp
got it back together in running form,
left out the catch cans & shield panel cos that needed tweaking to fit and I really wanted to test drive her,
bonnet latch is 10mm wayyy too high and needs yet more adjustments.
aligned the headlights, went for a night drive, boy I missed her
soo much more to finish but she's almost ready for MOT on friday :cool:
OP
OP
pollyp
pollyp
bonnet latch was sitting wayy too high making the bonnet stick up by 10-15mm
discovered this top section for the latch was right-angled too steep & high
angled it down 45deg with a few sweet hammer blows and it fits back :cool:
front end assembled
ooh yeah looking spot on shweet parked at work :cool::cool:
OP
OP
pollyp
pollyp
beginning to suffer from the common old brittle expansion tank :rolleyes:
with her MOT tomorrow, thought it's time to replace her rusty old downpipe flexi-pipe. how hard can that be?
top section of all the stainless strands have broken apart from the constant flexing
chopped & prepped the new section
welded
but a simple 2hr job actually ended up as a frustrating 6hr PITA cos the flange was off-angle by 1-2deg so had to mark / cut / reweld several times before I ended up welding it in-situ with pigeon poop at desperate times :(
fingers crossed at her MOT
she passed! barely :D
OP
OP
pollyp
pollyp
ah shiiyte
bad news tonight. was just leaving town heading towards a local Kuruma UK car meet, boosting uphill to overtake when suddenly a loud crunching noise, some metallic bits falling down the car (I feared for bent rods etc), lurching with loss of power & misfiring, bright oil light! :eek: lots of smoke and really bad sound of knocking bottom end :poop:
pulled over asap in a cloud of smoke with the familiar sound of silence and dash lights and thinking Oh Fcuk what now?
she quickly drained all her oil down her pants :confused:
called up Greenflag to recover her back home. my Odyssey gel battery is rubbish with lights, it barely lasts long enough with hazards till the recovery came, had to keep it going with the emergency lithium jump starter pack.
dad soon came in the peugeot to provide lighting.
and the angel friend Kim arrived with the ohh soo essential cuppa tea :D:coffee:
nice lad Wayne helped get her home 3 miles away & home sweet home :cool:
soon see what the damage to my wallet will be tomorrow :rolleyes::unsure::confused:
