PollyMobiles Rebuild
AN4 in
AN10 out
As you've said is what id choose a restriction in the return can over-pressurise the bearing housing. Much like a sticky pcv
You need a
1/8bspt to AN4
Turbo inlet (1/2"x20tpi) to AN4
Turbo outlet (7/8") to AN10
AN10 weld-on
2x AN10 female to hose end
2x AN4 female to hose end
Get spare olives too
I'd wait for the new turbo with regards to fittings though
Pros/Cons
Crimped is guaranteed to work, AN/JIC can leak if done incorrectly
Cost variation
Other than that AN/JIC wins
If you change thread you can change the fitting
Any length you need
OP
OP
pollyp
pollyp
AN4 in
AN10 out
You need a
1/8bspt to AN4
AN10 weld-on
Pros/Cons
Cost variation
Any length you need
absolute legend m8 ;)
those sizes seem to match up to my threads.
what olives? thought you just slip the hose over and then tighten to nut to clamp?
aye I'll wait till the postman makes me happy (don't look too much into that sorta stuff), verify the old/new threads still match, then order more bling fittings
OP
OP
pollyp
pollyp
last night I had a slight theory as to why the turbo might have always smoked after long deceleration downhill.
Coasting
when the car tilts downhill & I close the throttle, the deceleration & tilt angle makes the sump oil level slosh forward against the front ot the sump.
now I recall that the oil drain port is "just" above the oil level when static & full, so the slightest sloshing forward will make the oil pool block off the port and may even try to reverse & push fluid back up the drain hose.
the 9mm drain hose itself is prob already too small to gravity drain the oil flooding into the turbo core and the slight flow reversal makes it worse.
while the drain's having trouble ejecting any oil out of the core, the oil feed/pump/high crank rpm is still ramming HP oil through the turbo bearings and dumped into the core.
so with oil quickly building up pressure inside the core and the drain partially restricted and can't flow any more, the next easiest path is out the weakest leaking seals either via the compressor or the turbine.
during coasting, combustion stops and exhaust pressure drops so the turbine seal doesn't have exhaust pressure to fight against this HP oil and leaks past.
once the oil leaks into the turbine housing it just collects cos there's no combustion to burn it.
Accelerating
when I apply throttle to resume combustion, the HP exhaust helps the turbine seal push against the HP oil inside to stop leaking, and the burning hot gases ignite all the oil that's leaked & collected all over the housing into a heavy blue smoke till it's all burnt away. the acceleration sloshes the oil towards the back of the sump to unblock the turbo drain.
if true then the lesson is to fit the biggest drain hole I can (AN10 fitting) and abit higher then the oil level (which is difficult cos the turbo outlet pipe runs straight across the top of the drain hose where it meets the sump)
frank
but why are your piston crowns still partially damp tho paul ? have you tested for smoke with someone driving behind you ?
OP
OP
pollyp
pollyp
I've no idea, I've always suspected the cylinder bore was machined too coarse or wrong angle and retaining too much oil film so that it collects onto the piston top?
the oily dampness appears from all around the edges of the piston. this happened since day1, even if it was bedded on via N/A. if the valve guides were worn and leaking oil into the cylinders under vacuum, would the dampness pattern shape be abit different, more damp towards the inlet side than exhaust?
doesn't smoke when starting. now with standard exhaust she doesn't smoke at all. yes I do need to get someone to follow me with camcorder to see if this standard exhaust setup smokes at all. the turbo would always smoke/steam 20sec after high vacuum (perhaps due to these hose problems all along since day1 eh?)
frank
imo the oil is being sucked past the oil control rings paul (worse at low throttle/high mani vacuum) hence the damp crown rim, you cant really tell from the drivers seat, but i suspect that the car still currently chuffs blue smoke when booted
there is obviously also an issue with the wet turbine, i had that problem too, it was one of the reasons i ran a .5mm restrictor
OP
OP
pollyp
pollyp
the forged pistons only have 6 tiny oil ring drain holes and 2 wrist pin oilers. could this be trapping excess oil film?
think I once tested trying to keep inlet vac low / kept WOT then turn ign off coasting down, look inside and pistons were still damp. seems oil gets past the rings no matter what.
and the plugs always have a white hot ash look to em.
read somewhere that oil drainage are alright with big turbos cos of their size whereas with medium to tiny turbos the oil drainage is a big issue due to limited space and the oil has difficulty exiting so they often tend to smoke.
frank
the turbo bearings only need to be "bathed" in oil really eh paul, no actual oil pressure inside the chra, a bit like the u bend in a toilet :)
i tried having the oil return slightly uphill once and it smoked like crazy, that pressure back-up must have only been a couple of psi, i think you only need enough flow to keep the shaft immersed and cooled
frank
as for the rings, when we used to re-ring the kart engines with the old 1 piece oil control rings we never had any smoke problems (ghetto honed the bores with sandpaper) but when they changed to the 3 piece ones with the expander ring in the middle we had no end of problems (tried different honing methods etc) we used to order the old type and swap pistons over instead
OP
OP
pollyp
pollyp
would've thought they're the same as main journal bearings where the shaft floats on a hydrostatic film cusion of pressurized oil?
the toilet flusher system seems a nice analogy for oiling the turbo cartridge.
my tiny drain is just large enough to allow fluid to flow straight out into open space while still flushing.
but the moment the drain outlet becomes submerged/clogged/sloshed it acts like a U-bend and has a hard time draining without the toilet bowl level rising and potentially spilling over (oil leak & smoke).
OP
OP
pollyp
pollyp
my sister followed behind my car tday with my camera attached inside (but the non-HD cam didn't capture much detail from such long distance tbh) and she said it didn't smoke much. there's only the slightest little quick misty puff of oil at low 10-20 mph in town when I lift & accelerate in 3rd. so the engine seems fine :cool:
Andy_S
I Love Booooooost!
What u could do is do a dyno run or ask can you try and find the problem using their dyno.
Sent from my iPad using Tapatalk
OP
OP
pollyp
pollyp
so I strapped the camera under the backbox and went for a drive
0:13 cold start with no smoke.
1:40 drove around the block to warm up, exhaust steaming from cold pipes, and then check the timing.
6:40 engine warm and timing checked, I went for a drive.
11:40 WOT uphill, the ECU map said it should be running 10-12AFR and it appears to smoke abit rich but the wideband shows a lean 14-15.5AFR?
15:30 another WOT pull, again slight rich black smoke but showing lean.
the wideband giving strange readings of going closed-loop when it should be open-loop, and at one point showed an E8 error so I think this sensor is getting old or contaminated from the oily turbo & trackdays.
OP
OP
pollyp
pollyp
just purchased all the new hoses & fittings ahead of the new turbo arriving. not sure if the fittings are the right size (so many different conflicting BSP-NPT-AN thread charts not exactly matching some of my measurements) or if the turbo will use exactly the same threads but can't afford to wait around.
H701 recommended "torque_uk" on ebay and they had all the fittings I was looking for, totalling £72 o_O
1 x AN4 to 1/8" BSPP adapter for the engine head
2 x AN4 straight hose fittings
1metre x AN4 stainless braided oil feed hose
1 x AN4 to 1/4" BSPP adapter for the turbo oil feed port
1 x AN4 to 5/8" BSPP adapter for the turbo oil drain port
2 x AN10 straight hose fittings
0.5 metre x AN10 stainless braided oil drain hose
1 x AN10 steel weld-on fitting to MIG weld onto the sump
OP
OP
pollyp
pollyp
considering the wideband sensors been kinda slow to heatup and starting to show E8 errors, made worse following the smoking turbo issue, I guess I should buy another £70 sensor before japday just incase. can't believe I brought one back in 2012, then march 2015 and now may 2016? :/
jeezus this is costing me alot these past months.
OP
OP
pollyp
pollyp
just realised that the straight AN10 fitting at the sump may possibly foul the wideband or downpipe looking at this pic
so spent another £15 on a AN10 90deg fitting :rolleyes:
OP
OP
pollyp
pollyp
I am slightly concerned about what timescale my new turbo will be delivered.
Everything is riding on getting the turbo asap, in thought it was gonna be delivered next day.
The basic turbo technics website has no mention of any delivery or build times and some googling shows forum ppl complaining of over 2weeks waiting :\ have to ring em.
Polly, is it possible to construct the oil return higher up on CG engines?
Everyone in the SR crowd is highly against welding bungs onto sumps due to the high risk of failure. On those engines you can tap straight into the block, like this:
Regarding the wideband, are you using the Bosch LSU 4.2 or 4.9?
OP
OP
pollyp
pollyp
FFS friggin fuming at turbo technics! last thursday I googled the s116 turbo on their website and placed the order through their website and got an email to confirm it.
tday I rang sales to check delivery date, guy ask did I use their website...yup.
ahh he says cos their website is soo old outa date (yeah go figure) it doesn't process orders there. o_O
W.T.F? so he can see my order details there but the order & payment didn't go through..nope they have to setup some account before placing order. :confused:
oh ffs so where the feck did that payment go? o_O:rolleyes:
I asked if they have em ready in stock or built from scratch, they're each built to order.
erm how long, upto 5 work days. wth japday is 14th next week fck off. :mad::rolleyes:
erm ok if my order hasn't been processed and you take THAT long to get to me, I'm gonna try ring another company that already has em ready...
rang CGB Motorsport (a renault 5 GT turbo specialist), they have all sorts of stage 1-3 turbos ready waiting in stock for next day delivery!
http://www.cgbmotorsport.net/turbo-technics-stage-1-t2-turbo-996-p.asp
fcking yess please I don't care how much, send the fker here asap.
so it £527 including the £72 surcharge and £8 delivery. once I've returned my old turbo back to refund the surcharge it'll end up costing me £455.
asked bout oil line fitting sizes, says they're same as the renault 5 lines so straight swap. but mines a conversion, he doesn't have the thread info at hand, meh.
what about oil restrictor? nope not needed or included. if its needed, they'll include it. only turbos they've seen with restrictors are the ball bearing types.
gawd what a waste of my time. gonna call back turbotech to cancel/delete any of my orders/accounts.
OP
OP
pollyp
pollyp
The turbo drain port is too low to plumb towards the block without a serious kink restriction or slight u-bend and the compressor outlet pipe is also in the way.
It's a LSU 4.2
OP
OP
pollyp
pollyp
new turbo gonna arrive any minute tday :)
just spotting the pic last night that the oil drain could be a flange
so I may have to order a AN10 oil drain flange on ebay
OP
OP
pollyp
pollyp
New Turbo
Tday is a happy day :D I received my new turbo technics T2 stage 1 turbo from CGB motorsports, new turbo gaskets and ticket passes for JapDay :cool:
fitting instructions
Turbo Technics model S116
Serial #16D01X
for a Renault 5GT
I send my old turbo back to CGB
all balanced to 0.3G at 100k rpm
and inspection sign off
comes with vibration test results
look at this little beauty :cool::cool:
yay the drain is exactly the same screw type so no need to order any flange adapter
-13 marking on the turbine housing for some sorting reason
how nice of em to fit this adapter, this could mean I could fit the AN fitting straight on?
wastegate actuator number 10364-04
according to turbo technics it's a 12.3psi / 0.85bar unit
http://www.turbotechnics.com/components/t2actuator.htm
clean turbine
ID stamp
the same 5/8" BSP oil drain port as the old one
for the WG actuator lines, I'm gonna remove this compressor housing grub screw and swap the hose fitting from the old compressor.
0.48 A/R ratio on the compressor housing
a H mark on the turbo core towards turbine and a K2 marking towards the compressor
actuator locking nuts
old drain adapter fits straight on to verify the threads match
comes with new turbine housing studs
turbine housing marked as 0.47 A/R ratio
fresh machined WG port
noticed this little scratch in the compressor blade (for balancing?)
and a speck of metal dirt
new gaskets arrived too
will be clocking the housings to the correct position next.
awaiting new hoses soon.
then I can begin the long task of removing the difficult sump and reweld a new AN fitting onto it.
OP
OP
pollyp
pollyp
looking back at 2010, my old WG actuator label also said 10364-04 so they both have the same 12.3psi setting :)
OP
OP
pollyp
pollyp
Is it easy to rotate the housings on this one. Doesn't void your warranty does it? Looks very nice.
real easy to clock the housing, just loosen 4 bolts for the turbine side and at the compressor side you just unhook the c-clip and turn. doesn't affect warranty at all.
OP
OP
pollyp
pollyp
more detailed assessment. the WG actuator has this much preload
here's the compressor wheel, note the balancing grinding on the nut
turbine end. balancing grinds on the nut
more balance marks on the compressor
speck of metal debris blown clear and all oil residue wiped clean
this grub screw port was abit tight
it bleeds air from the housing. will be used to control the actuator
slight mark from the c-clip
little rib notch for the c-clip to rest against
markings on the outlet
carefully used a tight allen with extension to unscrew the grub
to expose the bleed port
screw the hose nipple on
the big c-clip wasn't fully clean so I wire brushed it
reassembled the compressor onto the core with the compressor outlet & oil drain both pointing down
new turbine housing
fresh machined WG
can just see the WG port and where the gases spiral around the housing
these bolt holes go straight into the housing
machined flange holes. I'll need to weld some nuts underneath here
view of the turbine port from gases pov. the clamping bolt hole at top and the WG port at the bottom
fitted the turbine and studs but tomorrow will need to take it back off to weld the manifold nuts underneath the housing flange.
Low Rider
Poindexter
Founding Member
Moderator
Never had an issue with nuts working loose on the manifold/turbo flange. I have got a Cu gasket, so perhaps the distinct lack of give provides a good clamping arrangement.
I use Nordlocks on the down pipe to offer protection for the Zircotec coating and to make sure it stays put.
OP
OP
pollyp
pollyp
happened twice on trackdays where the high freq vibration simply loosens 1 or 2 like an impact gun.
cadwell park
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-119#post-704086
and blyton park
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-137#post-726199
OP
OP
pollyp
pollyp
before welding the nut to the turbo flange, test the settings on a similar thickness piece. running at Max/2 voltage with wire speed 7 gave good penetrating smooth stable weld but at the end of welding, the wire frequently continues burning/balling up towards the contact tip and sometimes jam.
turning up the wire speed to 7.5-8.0 helped reduce the balling up but builds up too much metal. just have to deal with the balling up since it's just tacking stuff.
tacked the nuts in place
flange surface is abit scratchy so I sanded most of it down
the bolts holes at the front of flange wasn't fully tapped all the way through so fixed that
turbine housing bolted up with some lock washers
manifold bolted up
installed the actuator
fit new studs and embow gasket
but this ain't right
this corner ain't sealing
the gasket fits the pulsar GTIR elbow but the T2 housing is slightly smaller
so notice on the old gasket at the left side where the T2 housing just touches the GTIR elbow by 2-3mm
so guess I'll be reusing the old gasket
turbo assembled & ready.
tday I missed the postman with the new hoses etc as I was in the garage at the back so gonna pickup tomorrow. meanwhile I can begin removing the sump and start prepping it for the new drain fitting
Low Rider
Poindexter
Founding Member
Moderator
Would you recommend the Zirco coating Dave?
For me it made a significant differenct to under bonnet temperatures, (which was the objective), as the exhaust system has a large surface area being a top mounted turbo. We also used it on the etype but went for the performance white to match the car. It made an even bigger difference there as the uncoated headers would heat up the passenger compartment a lot and make the car quite uncomfortable. There is however a lot of piping very close to the footplate / tunnel. Coated it's barely noticeable.
It's not cheap stuff but it is bloody good and does what it claims in thermal terms. Nothing in it 'performance wise' though.
OP
OP
pollyp
pollyp
after running N/A for afew days, the wideband sensor in the standard manifold only has a light dusting of soot compared to the heavy coking of soot with the old turbo
removed the sump, almost forgot what a PITA it is having to remove the downpipe, lower brace, swaybar, and center beam to drop the sump.
all intact
Hmm one of the windage tray bolts has vibrated off, can't find it in the sump yet
oil pickup collected just light fluffs of sealant and dunno if it could be peeled paint from the sump walls
rear end intact
the drained sump. really no point painting the insides of sumps cos the oil preserves it anyway
the epoxy sealed oil drain I'll have to cut out
oil drain from inside. the old TIG weld prob has alot of porosity. I'm wondering whether to cut the old fitting off and simply weld the new one on, or cut that section out and weld a new thicker reinforcing plate over it with the new fitting?
the printed engine mount insert has broken up abit from the harsh vibrations
can see how the hollow sections have been crushed. gonna redesign with more filleted edges to reduce crack points and print it out as a solid piece
OP
OP
pollyp
pollyp
best car guy ever :D
:oops:
loving it that you are still around!
thank you Mik :)
life may go up or down but kasandra's always been there for me and my passion is still here :cool:
will be nice to catch up with you and everyone at jae ;)
OP
OP
pollyp
pollyp
Collected the new AN hoses & fittings today :D
1/8" BSPP to AN4 adapter
has an inner bore of 4.3mm so it's only 1mm less restrictive than the old 3.5mm hose feed, but considering the turbo oil feed port size measured later on, it's close enough tbh.
thread matches the old adapter so will fit into the head oil port fine
AN4 Hose end
4.3mm bore
AN4 stainless braided hose
5.5mm bore
AN4 to 1/2" BSPP
has a 4.3mm bore
but here we have a big problem, it doesn't fit! :(
the outer dia is slightly too big
the 1/2" BSPP thread pitch is slightly too coarse
the adapter that came with the new turbo has a AN5 size tip. the AN4 head I ordered has a 4.3mm bore while the AN5 adapter from the new turbo has a bigger 5mm bore
the AN4 & AN5 heads have similar thread pitch
Turbo oil feed port
has a port size of 5mm whereas the old turbo had 5.5mm
Turbo oil drain port
the same 13.5mm port as the old turbo
AN10 to 7/8" BSPP
has a 12.25mm bore
but the thread is wayy too coarse and won't fit :(
AN10 hose end
has a 11.5mm bore (just 1.5mm bigger than the old hose, would be better if it was 13.5mm but it's at least an improvement)
AN10 stainless braided hose
has a 14mm bore
AN10 90deg hose end
for the sump fitting
for welding onto the sump and has a 12.4mm bore
OP
OP
pollyp
pollyp
ok so I need resolve this issue physically rather than guessing online cos I dunno the exact matching thread size and would be wasting time waiting for orders.
so I drove to afew local hydraulics places to locate a matching adapter.
the first shop didn't have any suitable matches or would have to order some fittings over few days. nope no chance, need it now.
went to second shop, the guy was just about to start lunch break but gave it a look.
ideally I'd like to find adapters where I can still utilise the AN4 & AN10 fittings I've just received but matching the turbo ports odd threads seemed troublesome.
my worst case option I dread would be to utilise the adapter that came with the turbo and I'd have to send all the hoses back and upgrade to bigger AN5 oil feed fittings, meaning more wasted time & money.
the solution was to get an AN4 adapter and custom machine the other end down to 1/2" UNF 20tpi to fit the turbo, so now I can simply use the AN4 hose fittings :)
for the drain side, my old adapter goes from metric 22mm to 5/8 UNF and they added afew adapters to convert to a AN10.
costed just £10 for the two adapters and I can now use the AN4/AN10 fittings but the messy drain fitting conversion is too long
so lets join these two adapters together. verified it's steel so can weld em.
cut the obsolete threads off
grinded/sanded the faces flat.
the AN10 fitting is 12.2mm bore while the metric 22 fitting for the turbo is a larger 12.75mm bore.
so to chamfer the sudden step difference and to help keep things concentric, I drilled a slight 12.5mm hole into the AN10 fitting and use the drill bit to keep them lined up during welding
tacked & welded
grinded flat for the socket tool
here's the chamfered hole size difference
it all fits together nicely now and the amount of overhang matches the old hose fittings
the complete series of fittings
now the new series of port sizes appear much better
now to replace the sump drain fitting, I covered the insides to keep out dirt
time to chip all this epoxy off
that epoxy certainly did it's job of bonding / sealing hard onto the metal.
there's a dilema of either:
- cutting the whole section out and welding a new thicker plate on.
pros: eliminate the porous cracked TIG weld, have fresh smooth metal to weld new adapter onto, can relocate adapter towards middle of that rib section, stiffer mounting plate
cons: more time cutting, drilling & carefully matching the new plate, welding a large plate section that'll be submerged below oil level induces higher risk of oil leak if my welds ain't perfect.
- just cut the old adapter off and weld the new one straight over the previous TIG weld.
pros: quick & easy, less risk of oil leak
cons: welding over previous porous TIG weld (but can always apply more MIG weld), same thin sump sheet metal that can flex/crack
decided option 2 is best.
OP
OP
pollyp
pollyp
If your sump leaks, let me know Paul and I'll chuck one in the post for you
cheers karl.
considering the sheer amount of work in custom precision welding this sumps oil control setup, I'll only replace if it was completely irrepairable.
