Hi people,
Got an issue, I had cylinder 4 misfire fault code for a while. I changed the injector and it had sorted the problem - I had no cyl4 misfire fault code for a few days. Today started the car, left it idling for around 2-3 min (it idles nicely at around 250rpm so very low idle), and then checked the fault code reader and I have 'pending cylinder 4 misfire'. When I touched the exhaust headers, cylinder 1-3 were hot, and 4 was cold, indicating that cylinder 4 isnt firing?
Disconnected battery, swapped the coilpacks for cyl1 and 4, thinking that it could be a faulty coilpack. Also unplugged and replugged the injector for cyl4. Restarted car and let it idle for a few min, now all 4 headers are hot. Drove the car for a few min, now I have 2 pending fault codes - cyl3 and cyl4 misfire. Car drove fine though. I have driven on 3 cylinders in the past and I know what that feels like!
Am I right in saying 'pending fault codes' aren't a massive concern as its only happened once and the misfires aren't reoccuring in the engine cycles?
Maybe the excessively low idle causes misfire when the engine starts, but then its fine?
As for the cyl4 header being cold, I am stumped, maybe the injector wasnt plugged in properly...
Any advice is greatly appreciated.
