Open Grill and FSE Power boost
B
benmicrasr
Sorry if this is abit of a dumb question,what is a Fse Power Boost value?How much are they and are they easy to fit?
If you have got an open grill how does the mesh attach and do you use one bit of mesh for the 2 grills or a seperate bit of mesh for each grille hole?
Help is appreciated, many thanks Ben
a power boost valve increases the pressure in the fuel rail to allow more fuel to pass through an injector when open on a set duration. Pointless mod unless you have some decent mods to begin with.
You can mesh your grill either way, but 1 large mesh would be easier and better imo.
which shape u got? the one with the grille in the bonnet? if so u need 2 pieces of mesh, and u can use fibreglass to hold it in, or u can split open the 2 pieces of the grille, the chrome and the black, and put it inbetween and that alone will hold it in.
If its the sperate grille from the bonnet, one piece of mesh will do.
Got the pre facelift, what is the best way to hold the mesh in place then?Are the grille bits easy to remove?Thanks for your help
