Try to get a white sheet down over a weekend and narrow exactly where it's coming from, I say pick a weekend because if you're in a rush to leave for work or something there's no time to be poking around trying to trace back where it's dripping from, you just need a plumb line to figure out what's directly above the centre of the drips, and then look for the path the oil took if it didn't drip directlyThank you for your reply, there is oil appearing on the floor which I must try and stop (if I can) I was hoping there was a typical leaking part.
The leak would seem to be across the back of the engine. (don't know where of cardboard popped up from
