oil change ?
W
wezhoy
is the engine oil linked to the gearbox oil, or do i need to top em up seperatley ?
getting serviced in a month but oil is a wee bit low !!
if they r seperate where do you top up the gearbox oil ?
Yes they are seperate. The gearbox doesn't need topping up as it's a sealed unit - unless you have a leak of course. Just normally need to drain it out and refill. You have to unbolt the speedo drive cable from the gearbox and fill through that.
