NISSAN Micra Radio Code Please!
Hi! can you please help unblock my radio?
I just removed my ORIGINAL BLAUPUNKT radio and i notice that the sticker from behind is missing, but i found this codes attached.i have no clue what that mean, i tried the 4 digit code but it wont work.
I attach below the back codes.
28 185 AX613
HP-3123
And another codes are engraved on back radio frame:
8 635 123 393 0
>St SN<
28 185 AX613
HP-3123
8 635 123 393 0
>St SN<
Hi Jhon, can you unblock this radio or i should buy one from scrappy?
Hey don't suppose you could source a code for my 2008 160SR radio?
Serial no - PP3000MB 0004073.
It's Nissan part no - 28184 BG00A
Model no - PP3000M
Cheers
Lee
Hi, felt so pleased with myself for fixing my flat battery on my own, but now the radio needs a code :-( I would really appreciate it if you could help :)
CA8A5179887C
Hi John, just bought a Micra 1.2 08 Reg battery was flat so radio is looking for a code would there be any chance you would have a code for it.
Serial No would be PP3001MB 0016579. If you had it that would be great
Hello,
Same as many on here I’ve replaced my radio without realising I would need the code. Any chance anyone would know what code I need?
My serial number and product code are as follows.
Bp334936380224
7643349318
Many thanks in advance
John_D
Radio Code Guru
Try this one : 1593.
If it dosent work maybe @John_D can find other codes. Good luck
Hi,
Please help. I need the code for....
BP234631975834
7 642 346 318
Cristian
Like the previous person that replied, I can confirm that the code for the serial number that you posted is either 5593 or 1593 (probably the first one). If it 'didn't work' then the reason is almost certainly that you have not used the correct button, after inputting the code, to confirm it.......
Yeah I think it was my issue. What is the button to confirm it please?
Thanks for your response by the way.
Hi, could anyone help me with a code for my radio please? The screen says Serial Number is 9592600, Device Number is 7612830031. If anyone could help me out I'd be very grateful!
Hi All!
2012 Micra, needed new battery and now looking for the code....
SN - 2405786
DN - 7612830051
DATE 11.08.23
Any help would be much appreciated.
hi there,
can someone please help my battery went dead and i need radio code.
blaupunkt-werke gmbh
BP234632008317
7 642 346 318
any help would be most appreciated
Hi I'm hoping you can Help Me too
Recharged Battery lost Radio and code with documentation doesn't work
Pulled Radio and has Different Barcode to Documentation
BP5387 8 9963794
7645387618
e1024199
Just Waiting for Wait 1 Hour (Sigh)
Would really appreciate any Help
John_D
Radio Code Guru
BP5387 8 9963794
7645387618
e1024199
No worries 0373 should solve the problem...
