NISSAN Micra Radio Code Please!
Hi. This thread seems like just what I need. My battery died and radio reset. There was no code written in the manual from when I bought it. Could someone please tell me the code?
Serial - 2386246
Device - 7612830051
Hi All - same issue please - can someone provide me with an unlock code for my Nissan Micra Radio
Serial number - 3139910
Device Number - 7612830023
Date : 10.05.10
Any help would be Much appreciated!!
Hello John!
I need help with a radio code also. The serial is BP334947328897
Need to get my music back, the code thats in the glovebox is not working:(
John_D
Radio Code Guru
Is there anyway of getting my serial?
I just checked your VIN and from that I see that you appear to have a 2014 red K13 1.2L 5 door hatch, with satnav (in Holland?) ....so sadly AFAIK the only way that you are going to get the unlock code is by going to the Nissan main dealer and paying for it.....
John...
Hi John. I was wondering if you missed my message above, or if this radio type is something you cannot help with. If you can, it would be much appreciated. If not, thanks anyway.
My radio is locked and requires a pin.
Nissan Micra
Serial - 2386246
Device - 7612830051
Hello!
Bought one of these Micras for my girlfriend, all good except it's asking for the radio code. I've tried everything but I can't find it. Can anybody please help?
Serial Number is: CL081690101839
Hello John,
My battery died and radio reset. There was no code written in the manual from when I bought it. Could you please tell me the code?
BP5384 6 951 228
Nissan MMR CD-G: 7 645 384 318
e1: 024173
I hope you can help me!
We have rented a Nissan Micra and the radio is locked. Could you please provide the PIN to unlock it?
Serial: DW5AN01777
Part: 28185 3HN4C
Prod Date: 15 10 09
John_D
Radio Code Guru
Hello John,
BP5384 6 951 228
e1: 024173
Another BlauPunkt radio that I can't decode because the serial number hasn't been typed in correctly :rolleyes: .....There should be 12 numbers (sometimes a letter in the fifth place) not 11 after 'BP' , check the number and re-submit it ....
John_D
Radio Code Guru
My code doesn't start with BP, are you still able to get the code for me or is it a lost cause?
Probably a lost cause on here, I can only decode BlauPunkt radios, someone else might have different software ...... The Fujitsu radios are normally fitted to cars for the Australian market.........
Hello John and all
Media player is locked micra2013 how can i find the code thanks alot
Mi 9T cihazımdan Tapatalk kullanılarak gönderildi
John_D
Radio Code Guru
Hello John and all
I suspect a Nissan main dealer may be your only recourse........ You might get lucky with an eBay code supplier, but that is a long shot..... ☹
John you are an absolute champion replying to all of these!! I've been trying to work out the formula to no avail after my poor car battery died. Thank you!
BP 5387 6 9684120 [126]
7645 387 318
Hi everyone, this seems like great place to get some help. I recently changed the battery on my Nissan Micra and was surprised when i couldn't use my radio any more.
This is the numbers i got from the back of the stereo, i hope that someone can help me.
Thanks!
BP538469502459
7645384318
hello there! can you please help me with the code for my micra the radio serial number is CL081690088781
Thank you in advance
Hey, I got a second hand Micra from 2010, the battery failed recently (turns out it had it's original battery from 10 years ago) and we didn't reset the stereo code before switching the battery.
The car was a write off that has been fixed up and only came with its most recent not certificate.
My dad helped me check for the radio serial code its,
Bp738398860728 any help would be appreciated as it's still got one of my CDs in it!
So I’ve been without a working radio for about a year now since I had to change the car battery. Any help would be much appreciated!
BP334958111759
Hello all,
As I see John is working hard here. I had the same issue as you, battery went out and the radio locked.
I called the official dealer and did not wanted to help because my car was imported from another country they said!
So I found a radio code calculator and seems to be working.
@Admin is it safe to share this file here so the members can use it?
In the mean time try these codes please:
serial number is BP334947265311
@petephilp try 4322 or 0322
Hy , i need some help whit my Micra stereo code :D , BP738398858449 , 7647383318 thx
@DanyBau try 1233
BP334947239363
8635123392
@srdyns try 1630
7645 387 318
@Rhi_D try 4401 or 0401
Hi, Can anyone help with my Micra stereo please. Serial Number is BP5387 6 9669877. 7645387318. Thanks
@Faz1961 try 8996 or 0996
BP538469502459
@jetstorm try 7305 or 1305
@Morgane skye try 7805 or 1805
BP334958111759
@L.Thorn try 4238 or 0238
Hi Keith, try 8932 or if that fails 0932
Hi can u help me i brought a Nissan mirca 2005 which has be removed but now the stereo the bloke i got off has made that has no signal for the radio or bluetooth don't work any more i could use the the one that belongs to the car but i still have but no code and couldn't get the 1 hour wait off it can u help how to get the code for it please bes
