NISSAN Micra Radio Code Please!
Hi.
I really need a radio code. I have Micra 2004 (1.2). I removed my car radio and looked for code or serial number. All i see was those :
AX607
4137507
Also i found that numbers. I hope those are will useful
K121217501
28BC8FE56D9B
28015217
The same story as everyone else, the battery ran dry, no code recorded.
Would appreciate it if you could please provide the code for the following radio:-
Serial No: 2398514
Device No: 7612830051
Date: 11.06.21
Thanks in advance!
Hey, can you also help me when possible?
Lost pin after got new battery.
Serial number 8884554
Device number 7612830091
Much appreciated!
Another one here asking for your wonderful help John!!!
Similar story to the rest - just bought a Micra with the code needed but I don't have it!
Serial number is BP334947259651
Hope you can help me out! ?
Alfie
John_D
Radio Code Guru
Alfie
Hi Alfie, finally someone who posts the right information, you have proved that it is not difficult to read back a bit on the thread to find out what is needed to get an unlock code, so I can help you ;).... try 6710 or 0710...
Hello please can someone help me. I have a micro 2004. The battery had died and it says I need a radio code.
Serial number is BP334947288412
Emma
Hi John,
I hope you are well, can you please help with a code. This is what appears on my stereo now:
Serial# DW3AN33751
Part# 281853HN4B
It is a Nissa Micra 2014, if there is somewhere else I should be looking for the serial number please do tell me.
John_D
Radio Code Guru
Hi John,
Serial# DW3AN33751
Part# 281853HN4B
Sorry can only unlock radios made by BlauPunkt, yours was made by Daewoo.......... :oops:
Hi there,
My battery on my Nissan Micra 2003 has gone flat and I don’t have a stereo code.
My serial number is BP334947255786
Please could you help?
Thank you :)
John_D
Radio Code Guru
Please can you help me John? I recently bought a Nissan micra and it didn’t come witn a radio code!
BP33493638427
Thank you in advance xx
Check the 'BP' number again, there should be 12 numbers after 'BP' not eleven....(there may be a letter in place of the 5th number)
Hi.
Arriving here with the usual problem....
My girlfriends Micra battery was disconnected and the security code is requested, but I am a little concerned because the code she has noted is 3038 but this doesn't work.
Could you please work some of your magic and offer an alternative (hopefully correct) code?
8 635 123 393
BP334947226890
Regards
Mike
John_D
Radio Code Guru
Hi.
8 635 123 393
BP334947226890
Regards
Mike
Close but no cigar ;), try 3738 or 1738.....
Hello,
please can someone help me. I have a micra K12 and I need a radio code.
Serial number is BP3349 3 6395201
Bibi
