Hi everyone
I'm equatorlounge from Mauritius, software developer for 12 years now. I purchased my red K10 a month ago. Mechanics has always been my passion and here's my chance to put this to work, so obsessed to a point where I'm starting to work as a trainee car mechanic on weekends. 8 hours totalled so far !
Here are the major fixes my mechanic and I have worked on so far:
- fixed the radiator leak
- changed radiator nozzle
- changed water pump
- change part of gear equipment (flywheel, clutch disc, pressure plate)
(previous owner tricked me on this, but too late now, doesnt matter)
- changed my 4 spark plugs (champion)
- general 'servicing' (gear lubricant, engine lubricant, oil filter)
we did some few 'generic' changes yet i can personally tell you there's a long way to go (the electric part is like 4 out of 10) and im pretty much excited about it. every day i take note of the progress (in one month, there has already been a great improvement) and important things to note in order to work on my next 'move'
for instance, when there are steep slopes to mount and even if ive changed both the spark plugs and the flywheel/clutch-disc/pressure-plate), the K-10 has a tendency to turn off and I have to drive on 2nd or 3rd gear when normally I should be driving at 80kph on 4th gear.
i wanted to know what i should do about this before i go enquire with my mechanic, who always tells me this: hey dont worry, your car is fine, it's perfect, you're too paranoid...
hope someone can help me out on this and understands my situation..
i apologise for the quality of my english..
Thanks anyone
Thanks anyone
