New generic rear windscreen rubber install
My rear windscreen rubber was looking a bit shabby. Nissan have deleted the part, so either breaker yard, which your buying old rubber or source something completely new and different. I opted for the latter!
I didn't chuck it in hot water, just cleaned the area prior to install, about £15 for 4 metres it's gone in ok, I did require some thumb work and it's a bit fiddly on the corners.
The main test will be over the coming weeks, will it keep shape and stay in! I'll keep you posted!
OP
OP
nesty
Looks tidy. Ebay?
Is it a push fit or glued
Push fit.
Independent rubber company in Devon, found them on the net and they sent through 3 samples, which might fit, 1 did, which installed.
Time will tell if it stays in!
Push fit.
Hi Nesty,
I know you posted this a while ago but how has the trim faired , still ok? Also can you let me know the company you got it from and a part number or trim type that you finally purchased that fitted?
Thank you
OP
OP
nesty
Hi Nesty,
Thank you
Sadly, that vehicle went to the scrap in June, as the CVT gearbox went.
I have to say after 4 months, I had to start pushing it back in, (I didn't glue it, if I did results maybe different), so it wasn't a success over time IMHO.
Don’t suppose anyone knows the name of this rubber company in Devon ??
OP
OP
nesty
WT 02 was the part number and I ordered 4 metres.
Really appreciate that ! Thank you
