Can't find my haynes. I have a 1.0 LS. I want to increase my idle speed as the car shakes a little too much, please tell me how this can be done. Thanks
if i remeber rightly lil srew on the carb but i think some geinus at nissan made it so u need a special tool to do it. may be wrong though or break of the plastic guard
to adjust the idle there is a regular cross head screw located low at the back of the carb it manually adjusts the resting point of throttle wheel (the bit that the cable attaches too) It's quite hard to see, but if you look between the throttle cable and the base of the the bracket that holds the outer part of the cable in place you will see it poking out.
Cheers
Amy
AMY's right!
you must use screw driver to rotate the screw..different carb can rotates by your finggers..If not mistaken, clockwise to decrease down the rpm, anticlockwise to increase it..try your best
Hey thanks all. I will try tonight. From what I understand I must not touch the flat head screw on the side of the carb as this is to adjust the mixture which is spot on.
To adjust the idle I should find the cross head screw located at the back of the carb (between the throttle cable and the base of the the bracket that holds the outer part of the cable in place) Turning either way will increase or decrease the idle speed.
