My other micra is not starting up properly please help?!
Hi guys, my other micra is not starting up properly so i got clues. I am still finding what is the problem but it is tricky for me to solve this mystery problem. (i need your help!)
I checked ign switch and starter motor so they are ok. I tried to do jump start so it won't let me do it. I checked on these spark plugs so i noticed that cylinder 1 and 4 got liquid inside.:eek:
I don't know what to do with cylinder 1 and 4. is it completely damage to this engine?
JK
it could be one of many things mate, is it sparking ok ? have you tried a drop of fuel down the throttlebody ?
i havent check these sparkings yet. (how did you do it? sorry for being noob) I haven't put a drop of fuel on the tb yet.
all these spark plugs was gold/browish mix dirty wax/grease around on them. i will go and to see this car in an hour time so i will update later. i got my sr so is there any parts that i can swap over with other micra?
Ok guys, I just got some petrol so it's about one litre. How many ml do I need drop into throttle body?
This is first spark plug...
You can see some fluid in through cylinder 1
I can see chain from the engine oil cap. Dizzy is plugged. I can see all cylinders got fluid filled.
Yes it's two days so far now. It was working on two days ago.
On two days ago, I started the car so it was ok running up. I selected the first gear to move then suddenly, it stopped. It won't let me to start this engine so I got to push this car around. It wasn't working at all. I left this car in same place for two days now.
I think this engine must be damage now cos I can see all spark plugs got wet cos of these cylinders got fluid filled. (Pistons got covered by fluids so u can see one pic above) It must be damage to this engine then?
I just check on my Sr now. It got good dry spark plugs. None of these cylinders got fluid filled.
I will need to do compression test Tomo hopefully. Will need to borrow from my friend or to buy new one.
Its p reg poverty spec model 1.0. It's only done 61k miles. It got full tank ffs. I think it's time to get a new second facelift Micra soon.
am thinking it can be dizzy has been damp and wetted leads, swap it over and check that
Small update, I haven't give up yet so this car will be towing to my house tomorrow. It's about two miles away from my house.
Things that I haven't done it yet which are compression test, fuel pump fuse remove and also check on dizzy with ht leads
Anyway I don't understand why these some cylinders got oil filled. Is it damage badly cos no one haven't answer my question yet.
I tried bump start so many times. It won't work so I will do it Tomo. I will fuel pump fuse removal today
Yea I mean push start. I will try bump start tomo then. Anyway going to check fuel pump fuse now. Will update soon
Ok it's not sparking so I won't do fuel pump fuse then. It could be something wrong with dizzy and ht leads. I got no spare parts so I am still driving my sr today. I am off Tomo so I can tow this other Micra to my home then can swap with my sr parts.
So I need to get multimedia then. I never got one in my life. Tom told me it's very useful tool so I got to buy one tomo.
I don't have any knowledgeable how to use multimedia you know. Please can you tell me how to use media to test on dizzy and also others
I checked on YouTube before so now, I understand how it works. Still I need to know where do I need to connect and to test it. Thanks guys so will update tomo or a day after that.
