I was reversed into with a towbar. Towbar damaged my radiator but it didn't leak. I plan on going on a long distance journey so I thought I'd replace with a scrappy radiator. That second hand radiator would heat up above operating temperatures. I ended up buying a new radiator but then the new radiator would never heat up from cold or get to operating temperature. My mpg has also gone down the drain.
If you start the car from cold and drive it 70mph for 12 miles the temperature needle will move up 2mm. The minute you stop it slowly climbs to 3/4th of the way. You start driving and it cools down again. I've never seen the fan turn on since this problem.
New radiator
New themrostat not genuine
New temp sensor not genuine
Fresh coolant (pink)
New air filter
New fuel pump and oil filter with fresh oil change
Still get bad fuel milage along with the temperature problem
£20 for 115 miles
New radiator
New air filter
£20 for 115 miles
