Multiple flash codes tried lots and nothing works
Hi me again my Micra decided too die on me today on my way work. The flash codes I've got are 11,12,13,21,28.
I've replaced the throttle body with another I've got that I know works I've replaces the dizzy with another I've got that works removed the tape from the dizzy, I've also replace the temp sensor on the engine but it still won't rev over 2k its just hits it like its the limiter or limp mode I've tried disconnecting the battery too try and wipe the codes is there a way I can manually wipe the codes without a scanner? Any help would be taking with open arms I'm at the end of my tether with this car now cheers in advance max :)
Sent from my U7 Plus using Tapatalk
