Mods for under £50
Great shoe string budget mods
Lows, £0
Wheels £50
Rubbing strip removal £0
Twin tail pipe exhausts, around £15 for the stainless tube.
Reverse rims, £satin black rattle can.
Chin spoiler, £half sheet of mdf & tin of satin black rattle can.
Fender mirrors, about £25 from a Thai eBay seller.
some mods I've done over the years under £50 each:
painted engine cover
c725uz-165-jpg.30575
allen head engine cover bolts
82833670-jpg.26481
horizontal rear wiper
c725uz-313-jpg.30735
painted handles
c725uz-319-jpg.30587
k750-121-jpg.33297
enlarged airbox inlet hole
k750-77-jpg.31385
sealant smoothed windscreen strip
k750-111-jpg.30762
bypassed throttle body coolant line to keep the TB cooler.
k750-125-jpg.30771
^^ (will need to also delete the old fast idle waxstat mechanism in the TB to stop it being stuck open)
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-19#post-446256
k750-124-jpg.33770
a step further would be to crimp shut those TB coolant line for good
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-44#post-502488
dsc05643-jpg.36735
dsc05645-jpg.36736
de-meshed TB
k750-126-jpg.30767
K&N panel filter
516l-jpg.26488
sparco pedal covers
k550i-1654-jpg.32464
clear side indicators
k750-224-jpg.33304
bee-sting ariel
545e-jpg.26498
bypass the front sunroof drain through the sill to stop water being trapped inside (removes the main cause of the common rusty sills but if it's already started to rust it's hard to stop unless all the corroded surfaces are replaced. silly faulty design)
k550i-630-jpg.32378
k550i-628-jpg.32379
painted bumpers
k550i-740-jpg.30851
painted mirrors
k550i-815-jpg.29112
black vinyl sun strip
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-3#post-395998
k550i-1168-jpg.32700
braided brake hoses
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-4#post-397729
k550i-1225-jpg.26538
electric sunroof
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-5#post-399188
k550i-1360-jpg.32404
painted tyres
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-6#post-402970
k550i-1423-jpg.26553
reinforced clutch cable end pin
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-6#post-407293
k550i-1450-jpg.29367
plastic diy mandrel bent cold air intake
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-7#post-412735
k550i-1580-jpg.29379
k550i-1584-jpg.29380
k550i-1586-jpg.32439
suspension strut covers
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-19#post-446325
dsc03979-jpg.33889
dsc03980-jpg.33890
dsc04630-jpg.34293
copper PAS cooler
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-23#post-453731
1-jpg.29570
black vinyl sprayed dashboard
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-23#post-454171
dsc04603-jpg.29597
meshed bumper opening
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-24#post-455157
dsc04652-jpg.34310
skyline gts-t fuel pump
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-22#post-451466
dsc04327-jpg.33967
decat
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-40#post-488757
dsc05383-jpg.35772
DIY short shifter
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-48#post-507383
dsc05926-jpg.36899
dsc05931-jpg.36953
stiffer front lower arm poly bushes
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-50#post-509593
dsc06103-jpg.37051
dsc06106-jpg.29693
rear chassis diagonal cross brace
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-51#post-511242
dsc06185-jpg.36093
teflon inlet manifold spacer insulator, keeps whole inlet manifold side stone cold
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-50#post-510149
dsc06144-jpg.36129
dsc06146-jpg.36125
DIY stiffen exhaust hangers
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-53#post-514857
dsc06258-jpg.29713
dsc06260-jpg.37129
black ducktape sunroof cover. no need for that annoying rattling sliding cover
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-54#post-517136
dsc06322-jpg.27106
stiffen engine mounts with bodyfiller
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-78#post-588131
dsc08241-jpg.29908
ball bearing gear linkages
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-105#post-664250
dsc09050-jpg.28569
dsc09051-jpg.28571
everything else listed in this blog index
https://www.micra.org.uk/threads/pollymobiles-rebuild-blog-index.52496/
Lows, £0
Wheels £50
Cut springs?
£50 Modifications and Motor Insurance Costs!
Modifying the Micra will instantly put (£ hundreds) rocket up your motor insurance costs, year-on-year! Your existing insurer may refuse to cover you and cancel your contract when they learn of your modification plans. Not informing your insurer is not a lawful option, rendering your insurance void. Modifications may cost a great deal more than you planned for.
Marginal costs for each modification may be low at less than £50, but your time opportunity cost is worth very much more.
On balance, it might be more practical, efficient, reliable and less time-consuming to buy an original unmolested unmodified 1.3 or 1.4 Micra, ~ as a quicker daily commuter?
Good luck
50/60/70s cars had grease nipples on track rods when cars had steering boxes took 1/2 a day going round them greasing um up (showing my age now lol )
Those stock guides are incredibly flimsy. I've broken the thread off both of mine now. Stuck in the holes on the cam cover.
yeah they just use this weak fir-tree type fitting to barely hold it in place n mostly break off at a slight nudge
after printing my solid clips, I tapped full threads onto the plastic and it screws firmly in place on the head no prob :cool:
A tenner is reasonable. I'll let you know when I want some :)
righteo.
The ABS plastic I order is from here so the exact colour is limited by what they provide, hope it's the right green ur looking for:
http://www.makiboxclearance.co.uk/collections/all
Just doing this as a hobby so ain't stating if I'm a pro at it but I try my best and would test it fits proper on my car beforehand, It's for a k11 right?
when you want some, if you could verify the green or light green filament is correct, paypal me a tenner, I'll order the green, when it arrives after 1-5days I'll print it off as best n soon as I can, test it fits on my engine/leads n then post it off to you ;)
You seen the media cleaners? Spool holder and cleans the wire at the same time.
yeah saw some post bout that. when I heat the ABS upto 240c the plastic coming out would sometimes pop n upset the finish. some say it could be from surface moisture exploding into steam through the heater (hence the media cleaner mod), and some say it could be a deeper issue of trapped air bubbles from cheap poor quality filaments.
