Micra 1.0 k11 w reg over fueling on number 2 cylinder
Hi im new to nissans I am having major problems number 2 cylinder seams to be over fueling done a compression test and they are all the same when the car does start all that comes out of the exhaust is white smoke I just don't know where to look next
white smoke sounds more like burnt coolant ?
Number 2 cylinder when plug is removed all you can see on top of piston is petrol and the plug is totally soaked in petrol car was running ok till sat
if #2 injector was earthing out it would be held open fully, i would check the wiring
and the pdf manual explains how to remove the dizzy and test each injector for a click
