Micra 1.0 k11 w reg over fueling on number 2 cylinder
Hi im new to nissans I am having major problems number 2 cylinder seams to be over fueling done a compression test and they are all the same when the car does start all that comes out of the exhaust is white smoke I just don't know where to look next
frank
white smoke sounds more like burnt coolant ?
M
Number 2 cylinder when plug is removed all you can see on top of piston is petrol and the plug is totally soaked in petrol car was running ok till sat
frank
if #2 injector was earthing out it would be held open fully, i would check the wiring
and the pdf manual explains how to remove the dizzy and test each injector for a click
