Hi
My mam has a 2008 Micra (Tekna?) and apparently a light has come on, after showing her some pics in the handbook it seems its the MI/W light apparently it has come on then gone off a day or so later, I have vast knowledge of Nova's but not Micra's sadly and the handbook doesn't go into great detail, all it says is;
"If the Malfunction Indicator comes on steady or blinks (where fitted) while the engine is running, it may indicate an engine control system malfunction.... An engine control system malfunction has been detected... Take your car to a Nissan dealer and probably get robbed when your son can probably do it at home"
To me this could be many things but hopefully to one of you guys it might be a common problem or a well known problem
Thanks in advance,
Andrew.
Thanks in advance,
Andrew.
