Lowering kit
In need of a lowering kit that doesn’t break the bank (Spax/BC) style.
Don’t want modified shocks or anything of that sort, just proper k11 coilovers, preferably 40-50mm.
Will also consider 40-50mm springs for stock dampers ??
If this is posted in wrong place then please remove, cheers.
claiming 35mm here.message seller for details if front and rear
40mm shocks plus springs
I have read that you need an adjustable panhard rod on the rear beam if you lower the car a lot. Something to do with the geometry of the rear wheels when you fit lowering springs.
Yeh had that in the works??Gizfab adjustable or an RSR one
At what point do you need an adjustable panhard rod? If you lower the vehicle 30-35mm max, do you still need this rod?
Steve's hit the nail on the head. Corrects fitment and balance in the long run, even if the car aint being tracked.
Pics from Gizfab website
64549
