superls
K10 Tuner
Right then boys and girls, as you may know i advertised my SR this morning, so today i thought ID go outside and tidy the inside bla bla, you know the score.
I also thought id fire it up to move it, got in key in turn key, engine half turned over, flat battery.
Goes into the workshop gets my jump battery and jump leads, jumped it, boom fired up, however the engine light started flashing and then cut out after about 3 seconds.
turned ignition off same again run for 3 then cut out, engine light flashing.
Now i had this trouble in jan last year and it cos i broke the transponder pickup ring, but i havent touched anything this time
I took it off the road mid december, and since then ive changed the flywheel and exhaust manifold back to standard, and took the radio out nothing else.
The problem carries all the symptoms of a NATS issue but ive done nothing to instigate them unless the flat battery has done it?
Any ideas?
Any ideas?
