Little bros K11 makes knock-ish sounds when shifter is moved
The sound definitely sounds like something is loose, happens when the shifter (manual, just to add) is moved around. We traced the sound to somewhere above the cat and the metal heatshield(?) but we didn't take it out yet because we don't have a proper jack right now to use. To be more accurate it sounds like it comes from the other end gear selector linkage arm / rod (not sure what it's called). The car is a 1993 1.3 to be more accurate.
Sorry for the limited amount of info but that's all I have currently.. In short moving the shifter causes sounds to come from around above the cat that sounds like something's loose or has some play in it. Moving the shifter does not feel weird, feels the same it did before the sound started.
Thanks!
