Key code for radio/cd player
John_D
Radio Code Guru
Hello
I am new to this forum my partner just bought a Nissan micra and when we switched the radio the sign code appeared we have looked everywhere but we cannot find the code and the seller just told us he has lost the code. Can you please help me
BP538369452341
7645383318
Hi, no problems, try 3312 or if that doesn't work 1312.......
Hello
I have a 2005 micra and had to change the battery recently - and now the radio/cd player is asking for a code. I wasnt given a handbook when I bought the car and dont have a code. It is a factory fitted radio/cd player and not sure how to get it out to look for a model/serial number. The only number I have found is 55610190794 but not sure if this is the serial number.
Hope someone can help please
Estelle
Hi
I am having same issue being locked out of radio and needing code. where I do I find the serial number and part number please?
Thanks,
Abby
John_D
Radio Code Guru
Hi
Thanks,
Abby
The number needed starts with 'BP' followed by twelve numbers, it is usually found engraved on the backand/or side of the radio. You have to remove the radio from the dash to find it....
Is this simple to do myself on nissan micra (2005) or do you recommend I go somewhere for them to do this? Sorry I am clueless
John_D
Radio Code Guru
Well THIS video shows how to do it, step by step, decide for your self. If you have no mechanical expertise you are probably better off getting someone else to do it for you...
Hi.
I wonder if you can help me with a code for a 2008 Micra
Serial no. PP3001MB0034144
Part no. 276-0034-53
Nissan part no. 28185BG10A
Nissan model no. PP-3001M
Thanks in advance
Dan.
Hi.
Thanks in advance
Dan.
Hi.
Those numbers don’t look the same as the previous posts.
I have just removed it again and looked on the case rather than the sticker.
There ya a number engraved on it ,
CL081680034144
It is a Clarion CY00E
Fingers crossed, Dan
Hi John,
I popped down to my local garage who removed the radio and found the numbers for me.
They are as follows:
BP234746086897
serial number: 7642347318
Hope you can get the code for me :)
Big thank you!
Abby
John_D
Radio Code Guru
Hi John,
BP234746086897
Big thank you!
Abby
No problem at all, try 8107, or if that fails 0107.....
Hi.
CL081680034144
Hi John
Any thoughts on my codes please.
Life without a radio is dull.
Thanks. Dan.
Hello
Please help me.
I forgot and lost my code radio
micra k12 2004r.
serial number:
radio nissan
BP334947323333
86351233930
28 185 ax613
hp 3123
8 635 123 392.0
m5x6mm max
Thank you very much!
Hello
Estelle
Hi can anyone help me? My battery went flat today and the radio locked. I can't see any radio code in the owners manual
The serial number is 3141312
Help much appreciated!
Liz
John_D
Radio Code Guru
Liz
Have you checked directly under the steering column, the handbook black folder slots in there and just looks like a padding ledge if you don't know what you are looking for.........
Hi,
Am new to this forum, but I am after a radio code for my wife's Nissan Micra. It had a new starter fitted and we never received the code when we bought the car. Not sure exactly which numbers you need, but I have everything written down that is on the label on top of the radio itself.
Nissan Part No. 28185 BG10A
Model No. PP-3001M
170681 (is kinda stamped on)
Serial no. PP3001MB 0033906
It's a Clarion PN-3000
Design note no. T16509 / 205192
Part no. 276-0034-54
Thank you in advance for your help.
hi there i wonder if anyone could help with a code please for a nissan almera tino model pn-2316v serial CL044810064601 many thanks in advance Dunk
need radkoe code for 03 mirca
k121046512
cd5178568498
12035518
thats the sticker in the glove box, not sure if thats what you need for the code. please help thanks
Hi had flat battery radio CD states wait 1 hour
Now asking for a 4 digit code which I don't have
Although 1019 is handwritten ontop of radio code didn't work
Bp334936372897
Nissan mm cd k7643349318
322458 is other number
John_D
Radio Code Guru
Bp334936372897
Scrub the '1019', from the top of the radio and replace it with 3053 or 1053.....:)
hello all......
Im new here and Im want your help...
pls help me.... my radio is locked...
nissan MMR CD-G
7 645 389 318
BP5389 6 9260317
plsssssssss...........
