Key code for radio/cd player
Can someone help me with a code?
Blaupunkt Nissan MMRCD-G
BP 538971333974
7654389318
Thanks in advance for your help :)
Hello Guys,
My Micra was in service, they disconnected battery and now radio needs code.
I don't have card with code, it's lost somewhere.
Can anybody help me?
SN: BP7383 8 7796084
PN: 7 647 383 318
I would really appreciate if you Guys can help me!
Hello Guys,
PN: 7 647 383 318
Your unlock code is 1211, write it down and keep it somewhere safe;)
Can someone help me with a code for my Nissan?
Blaupunkt Nissan LCN
BP0003 9 4685526
7 612 830 003
Well that's a new one on me, never seen a 'BP' code starting with three zeros before.:unsure: However the software recognises it and comes up with the codes 5762 and 1762.....
Thank you for help but the code is incorrect... :(
The code is correct for the numbers that you supplied, suggest that your serial number is 'incorrect', how did you obtain it? You can only get the correct number by removing the radio from the dash and reading off the engraved number, starting with 'BP' , on the side or back of the unit......
Numbers on top of the radio:
BP - Nr. 7 612 830 003
Nissan part no. 25915BH00D
Numbers on the side:
Blaupunkt Made in Portugal BP0003 9 4685526
Nissan LCN 7 612 830 003
e1 03 5454
e1 03 5454
Just run those numbers through again and get the same codes. How are you inputting the code and what results do you get?
Looks like my software doesn't work on the much later Blaupunkt SatNav models:confused:....Just found this on the net and my software doesn't come up with the right code for that either.......:oops:
When turned on, the radio requests the code. As I enter 5762 or 1762, it is displayed that it is incorrect.
Hello
I have a 2005 nissan micra 1.4 SVE and had to change the battery recently - and now the radio/cd player is asking for a code. I don't have a code. It is a factory fitted radio/cd player. The number I have found is BP536556021495 but not sure if this is the serial number. Another number on the radio unit says 59730002536.
Hope someone can help me with the radio code to put in please?
Hello
Hi, try 8978 or 0978....
Hi! I disconnected my battery and I don’t have a code. I have the serial number of my radio: BP234631957276. Can you help me, please?
Kind regards!
Hi John, My daughter has just bought her first car a 05 plate nissan micra 1.5 dci and the battery has been replaced at some point and there is no radio code anywhere. it has a Blaupunkt radio the numbers i have found are: BP3349 5 81 40606 , e1(in a box), 022458 , 7 643 349 318, Nissan MM CD-K.
And on the bottom of the radio is 28 185 AX613 , HP3123.
Also i don't know if anyone can help it has rear parking sensors that don't work i have found the sensor box tested to see if there is power to the box,which it has. Also checked the buzzer and that works. There are 3 wires out of the sensor box Red,Black and Blue. Red and Black are connected but the Blue has the end stripped and taped up also the Black wire has a piece of the Blue wire spliced to it and the end stripped and taped up? It is a genuine Nissan parking sensor box RPS20 , 4MO168N1A. Has anybody got any ideas or wiring diagram please. Any help would be grateful.
Hi, Recently replaced the battery in my Micra and need a code. Would be amazing if anyone could help,
Thanks! Here's the serial and other parts:
Model: PP3001M
SN: CL081670006477
Other numbers I have found:
276-0034-54
28185 BG10A
Hi,
Radio reset after changing clutch on Micra. Missing code in the manual.
Any help with a code much appreciated.
BP538471204524
7645384319
Thanks.
Hi just bought a new car Nissan micra
2003 stock radio.
Details are:
Blaupunkt made in Portugal
BP334936345189
7643349318
any help will be appreciated !
