Key code for radio/cd player
Hi, if anyone could help I would be very grateful. My wife's Micra battery has gone dead and now the radio needs a code.
The details from the radio are;
BP234631999269
Nissan MM CD-K
7642346318
BP234631999269
Nissan MM CD-K
7642346318
Try 6816 or if that doesn't work 0816
Hi, friends. Can you help me? I have replaced my battery and now I need a code for my Micra.
Here are details
Blaupunkt Werke
BP 3349 3 6384311
Nissan MM CD-K
7643349318.
Hey, my radio has always asked for a code, I pulled off the front today and found the following codes:
66670023478 Nissan MMR CD-G
BP7-VA2892-016525223 AV01 8241
Can anyone help me? Thanks
Sorry don't recognise any of those numbers :oops:
Assuming it is a Blau Punkt radio the serial number (starting 'BP' then 12 numbers, though the fifth 'number' may be a letter) that I need, will be on the back and/or side of the radio body, only visible when the radio is removed from the dash...
Can somebody help me with my car radio code please?
Serial number is
CL052920071067
Part number is 286 9881 02
Thank you in advance
Marek
Serial number is
CL052920071067
Marek
Another 'Clarion' radio, sorry not got decoding software for that make, I can only supply codes for 'Blau Punkt' ones. Not sure if anyone else on here can help.:(
Hi my radio has lost the code I've removed the radio and there's a piece of card with these numbers on, 28 184 BC41A and ZH-912 are any of these the unlock code?
If not here's the others BP538761139239
7645387318
Can anyone help?
Cheers Nathan
7645387318
Can anyone help?
Cheers Nathan
Hi Nathan, try 3685 or if that fails 1685...
Hi all.
Could anyone help me out as my battery died and I have no code for my radio.
Any help would be greatly appreciate, thanks in advance :)
BP334958138269 serial number
28185AX613 HP3123 part number
Hi all.
Try 6924 or if that fails 0924
Hi. Hoping someone can help me to get a code for my Bosch radio on Nissan Micra. Details are:-
Serial number: 9588409
Device number: 7612830031
Date: 10.08.26
Thanks in advance.
Date: 10.08.26
Thanks in advance.
Not sure if any one else on here can help, but I can only supply codes fro Blau Punkt ones....
Hi Lexi, the code for your radio should be 5493 or if that fails 1493
Hi guys, so tried the codes and they won't work. The way I put it in was hit the numbers until i reached the right sequence and then hit the ^ button. Is this maybe the wrong thing to do? As it always says to wait 1h. Also, i've learned that if i leave the radio on and switch off the engine, the next morning the radio goes straight to snter the code, maybe it will help somebody. Thank you kindly
Hello, when I take off the front of my radio the cereal number on the back is 66670023478 NISSAN MMR CD-G
I can't actually pull out the radio so I've tried taking a photo of it that I can't seem to add to the comment :oops: so what I can make out is: BP7-VA 2892-0165252-23 AV01 8241.
Still don't recognise that format of numbers, but removing what appears to be 'extras' the code that I get is 3952 or 1952, sorry that's the best I can do.
Hello
I have a Nissan micra year 2010 and my radio asks for a code which I dont have unfortunately.
Could you please help me out with the code?
I have the following info:
Serial number 8820846
Device number 7612830023
Thanks in advance.
Hello to all! I had the same problem when the mechanic changed the battery. Now I have to wait an hour with the ignition on to unlock the "wait a hour" right?
I don´t know if you can still help me but, dear John_D the car is a Micra 07-2007 and the codes are:
Blaupunkt:
BP538962431371
the other is:7645389318
Thank's for your help.
After installing a new battery I really need the radio code:
BP334958139451
8635123393 or 8635123392
Could someone please help me with the code?
Blaupunkt:
BP538962431371
Hi, try 5088, or 1088 if that doesn't work...
hi unfortunately i lost my 2005 micra 1.2 visia s radiopass coz of batery change :( my serial number is BP234746090134...anyone to help me???
Hi, please any chance you can help regards my daughters 3dr Nissan Micra Oct 2003
she recently had a blown radio/audio fuse and now she needs a code as she has looked and she has lost it, we found a number at the back of the plastic housing (1653) but it has not worked, is there any chance you could help, would be a very appreciated and less hassled/pestered Dad.
number on back of radio is Blaupunkt BP334936353260
7643349318
many thanks.
7643349318
many thanks.
Try 5739, or if that fails 1739
