K12 Radio Codes
John_D
Radio Code Guru
Hi
I've just upgraded to a K12 :) This will be the third Micra I've owned, the other two K11's were sadly lost to rust. (Effie my previous one pictured, ended with a bang in an endurance race)
I've never needed a radio code before and the previous owner can't find it. I tried to follow a reset video on youtube to bypass the code but to no avail and having removed the radio to locate the serial number sticker (no mean feat for a lady and a screwdriver) the label is long gone but these numbers were etched on it. Could someone help with a code please?
BP334947262295 and 8635123392 0
Thank you very much indeed
Angela
Hi, try 5217 or 1217....
You are a star... first one worked. I'll keep a note of it in the ashtray for when I replace the battery as it needed a jump this morning - freezing in Midlothian countryside last night.
Thank you again much appreciated
Hello!
Pls if anyone can help I’d really appreciate. I need a radio code for the serial nr: DW36N00706073HN4B
Part: 281853HN4B
Date: 06.07.2013
Kind Regards
Hello!
Part: 281853HN4B
Date: 06.07.2013
Kind Regards
Hi, we recently bought a Micra K12 but the previous owner hasn't got the code for radio-cd. Please can anybody help me to find a code?
BP538469479459 and 7645384318
Kostas
hello members
is it possible to get my radio codes??
i got a new battery and now it doesnt work anymore
the sn is bp 334958131604
part nr is 7643349318
thank you very much
bert
Same story as most others, battery ran dry on second hand car with, no code recorded.
Would appreciate it if you could please provide the code for the following radio :-
S/N: BP538761141228
P/N: 7645387318
Thanks in advance!
John_D
Radio Code Guru
S/N: BP538761141228
P/N: 7645387318
Thanks in advance!
Hi, try 5403 or 1403....
K12 Radio Code Thread
This is the official thread for K12 radio codes.
Please provide your serial number (starting with BP) in reply to this thread.
Please bear in mind that the generous people that provide these codes do so in their spare time so please be patient when requesting a code.
BP5387 6 1122558
Thanks in advance
Hi John,
I've just inherited a 2006 Micra from my Nan and after replacing the flat battery, of course the radio wants a code. No details recorded anywhere.
I've taken it out to get to the label:
Blaupunkt BP 5384 6 9494356
Nissan MMR CG-G 7 645 384 318
Can anyone help with the code please?
John_D
Radio Code Guru
Hi John,
Hi, try 5298 or 1298......
After a failing battery and replacement, I'm lost for the code on my 160SR.
Found a Ser. No. On the device itself.
BP536556440074
And two other numbers LP 8 635 123 524-3
And LP8635123520-1.
There's no label on the device anymore.
It's of a MMR IDC-G
If anyone could provide some assistence it will be greathly appreciated.
John_D
Radio Code Guru
BP536556440074
And LP8635123520-1.
It's of a MMR IDC-G
No problems, try 8594 or 0594........
hello,
Please can you help me to unlock my Nissan micra radio.
BP538469511037
thank you
John_D
Radio Code Guru
Hi, battery went flat and now the code needs inputting, can anyone help?
BP538865051173.
8 635 123 615 3
I already gave you the code for this back in June after your request then for the same radio, go back, it's immediately after your one and only other post on here, and see that, and this time write it down somewhere for future reference!:rolleyes:
