K12 Drive shaft removal
Hi folks I am changing the timing chain on my K12 I have removed the drive shaft from the hub but having problems removing drive shaft from transmission. Haynes say you have to remove a circlip but I cant even see it never mind remove it, or do you just prise it out with a screwdriver?
andy_con
Club Member (Trial)
not the best way but you can leave the engine in place and do the timing chain that's how I did it. there is a big thread on it
