Micra 2008 petrol cranks only won´t run at all.Have tested the fuel pump pressure seems ok. Also checket spark seems ok.
If petrol sprayed into intake engine runs.Suspect the injector system have tested currency at injector connector measured 12.5 v (brown)
and 2,5 v at the red wire. Have checket bot the cam and crank sensor ok. What should be the next steps ??
