Saving only 25p/litre wouldn't tempt me either, some cars use slightly more fuel on bio (though other cars use less) but you couldn't gaurantee saving more than say £10 a tank.
Thing is, I'm talking 15p/litre to make it!
I've bought bio before and had a lot of trouble, they rush manufacture and often you do get crap in the fuel, but making it myself I can ensure it's good quality and 5 tankfulls would pay for a centrifuge, that's the only way I can improve on the 1 micron filtering I already use (which is far better than pump derv BTW).
It's not (only) contamination though, bio fuel can suffer from oxidation which degrades the fuel, some cars are ok and others aren't. VW for example say everything they have made since 1996 will run on it (I'm told you can buy Bio at the pumps in Germany) and I know several people who have run Audis on it for years. The problem with DCis is the fuel in the common rail sits close to the engine and gets very hot whereas an old mechanical injection system doesn't heat the fuel anywhere near as much. Bio burns cleaner and lubricates far better, runs quieter with less emissions and is carbon neutral.
You can't tell after a couple of tanks though and the Micra hasn't been 100% reliable running on dinosaur juice all it's life. With only 45,000 on it the EGR is playing up and the boost sensor has failed, I'd never know if it was the fuel causing the faults or the notorious Renault reliability.
Perhaps it's time to sell the Micra on then and buy something else, It's not proving that cheap to own or to run.
