If you mean the black plastic things, you can sometimes clean them out and get them spraying straight again
unscrew them from the lines, soak in warm water and dish soap to remove grease and bacteria, and then clean off and soak in vinegar to remove mineral deposits, Finally take a needle and syringe and spray soapy water through there in every direction, clean off in just plain water and test it out on the car
