hi can ya help me.
my rear left calliper is seized and the handbrake mechanism doesn't work (other calliper's ok) so i tried to take apart the calliper but i have a problem.
with the piston out the manual says you remove the circlip with circlip pliers inside the calliper but access is blocked cos there's this thick black collar between the central piston screw and the piston cylinder wall only giving a 5mm gap.
noticed a spring element inside that collar so i used a socket and g-clamp to try push it in but didn't budge.
tis really frustrating and had to reassemble it to park the car back.
neone have any tips?
