hello / how easy and what is needed to change the rear brakes on a k11 from drum to disc / thank you
hello / thank you for the reply / it does seem the best way to go / my problem would be getting one as I live in the Shetland isles and there are few micras here and none with rear discs so I would have to get one from the mainland and without seeing it you take a chance on its condition / I might just renew drums and back plates / thank you again / loganThe easiest way would be to replace the whole rear axle with the disc brake version. This is also the cheapest. You can pick up an axle from around £100 if you're lucky. You will need a new handbrake cable also. The swap is easy, its finding them that's hard.
Unless you specifically want discs on the rear then I'd replace the drumbrake assy. It's a lot cheaper.
hell o yes I think that you are correct / I will do that / loganUnless you specifically want discs on the rear then I'd replace the drumbrake assy. It's a lot cheaper.
