I'm running 10psi on a cg10 and I had to add a 5th injector as even with ga16s and a rising rate fpr I ran out of fuel (I know it's a dirty way to do it but I have 12.5/13 to 1 afr on boost now just hoping it stays together)
I had the same problem with ga16 injectors and my widebend pinned to lean when I got on the gas
Be sure to fit proper ga16 ones and a rising rate fpr Not the pink s@@t ones off ebay I got stung with those
But all said and done there is a right way and a cheap way to fo about things
Right being mapped properly
Ideally mine needs mapping as it's a rocket on boost but rich as he'll everywhere else it goes through more fuel then a small country I'm trying to trim it out with an apexi safc neo when cruising
And again buy a wideband money well spent
Sent from my SM-F926B using
Micra Sports Club mobile app
