K11 Door Chime delete!
#1
I'm after some advice on removing the door chime (the beep sound when the door is open and the key is in ignition).
I've been meaning to refer to the service manual for a diagram but that's half the battle, the other half is finding the wire in the car.. If someone has done this before please let me know! this beep drives me nuts!
#2
If i remember correctly the beeper itself is somewhere underneath the steering wheel. Id say just open the door and listen where the beep is coming from and disconnect it.
#3
I had a go at that, apparently my hearing sucks!
if you find an opportunity to, would you please upload a photo of where you found it roughly?
#4
Behind the shelve underneath the steering wheel most likely. Should be a yellow buzzer. I dont have a picture because i have a facelift. Different buzzer.
