Only turn signal lights work for now, tried with 2 different speedos and many fifferent bulbs. Ideas? It even popped smoke and burned some spots when i was trying out bulbs. Only one spot was working for speed illumination, then it smoked and it also died.
Edit: didn't check fuses today but i know there is a fuse named "Meter 10" could this be related to dashboard illumination?
SOLVED: For some reason the led bulbs that i bought caused damage and malfunctioning. i recommend using ONLY normal bulbs! The leds burned some spots to the point that they no more receive electricity!
