Hi ppl,
Firstly, Hello to everyone on MSC, great site with lots of info!!! I need some advice.
I have K11 (P reg), it's only done 36k and has served me well, however....
I drove it home from work the other day, parked up, all was well.
Following day I jump in to go to work, turn the key (I hear a slightly starnge noise - hard to explain - but only lasted a split second) and then it wouldn't start! And hasn't started since. I've checked loads of things like fuses, fuel, sparks at the plugs etc etc, all seems ok.
So digging deeper I did a compression check, here are the numbers from gearbox end (85, 50, 25, 35 psi)..... I know these are extremely low. It's like the timing is out or something!?
Anyone else had or heard of such symptoms!????
I'm stuck big time - I thought i'd run it past everyone on MSC before I strip it down.
Thanks in advance, Chris
