K11 1.0 dot ..can anyone help?
Q
Quentin Burns
Hi there....does anybody know if it's possible to disconnect or not run the automatic choke on start-up?? I find that the revs are really high when the engine is cold and I'm sure that they shouldn't be set so high.
Would be really grateful if anyone could offer any advise..thanks and kind regards..
thats about normal, maybe alittle high,
just tweek the screw on the TB
you don't want to disable the choke! your gonna have alot more problems if you do that lol,
Alienfish360 said:
nope, no spluttering at all, a perfectly smooth idle, no fluctuations
cool, i just tried my car and it idles at a perfect 600 but you can hear slight fluxuations which go when you put a small amount of pressure on the pedal
