K10 Ga16 Convertion
All it says is GA16 nothing else, but I think I've sussed it now. Ed put me on the right road which I should of known. Its got the dizzy that's no good for the conversion i am doing; the ecu type not carbs.
What I need to know is if there's a dizzy out there off any older Nissans that fits the GA16 which is just electronic ignition and got the vacuum port attached..
bob, i need to know what engine you have got?
do you have the ga16de lump?
ive got an idea of the wires but i couldnt get a picture to explain it,
on the dissy you have four wires means you dont have a inbuilt cas sensor
1 wire goes to the tacho on the dissy
on the coil the black and blue is a ignition feed
but ill grab the manual tomorrow night and if you have msn we could talk over that as its quicker
i stripped the interior for weight reduction to go faster. I used a bag of sand to see affects to handling, i dnt carry a bag of sand in the boot everywhere i go!!! LOL
its a diffrent head but you could try a GA16S or something like that, it will be trial and error, CA16S, CA18S, CA20S etc. all have them
The ST has more power standard than the 1.6 and exactly the same chassis/safety. Its probably just as heavy too since it has so much strapped to it.
i remeber seeing the kerb weight for the ST and its quite a bit more than a standard super s IIRC so it must be the engine that causes the extra weight i dont think a 1.6 is going to ruin the handling to much, bottom line is no ones done it so everyones just assuming for all we know it could make it better we wont know till its done ;)
I connot find a distributer around my area i need for this to run..can anybody help..
i need one off an 1990(G) to 92(J) non ecu type primera or almera,they are out there just not around my way.
its easy to spot its got the vacume pot on it the others havn't...
alot of scrappies will find the parts for you if you give em a call mate, do a search on google for simpson's salvage they are very helpful and have most of their cars listed on their website
I may be forced to sell it as i need the room so if anybody is interested in it make me a private offer all the hard work is done just needs its eletrics,drive shafts and exhaust as you no the shell is very good solid with no rust anywere,o and the suspension has been uprated with new gas shocks with lowering springs.
i was going to have a inlet manifold made up for it to run on bike carbs which i do have as well.
Its amazing what you can do in a couple of hours with some flat steel and 4 bits of 2" exhaust pipe.
Not quite finnished needs welding up and die grinding out to match the ports but dont they fit a treat though.
i still connot find this distributer i need around my way,PLEASE can some of you lot have alook in there local scappy,pre 93 non cat primera 1.6 its got the vacume pot on it here's a picture of the engine.
pic.php
everything is more or less in place now just wiring and pluming,drive shaft and being done is i speak so week so and it should be up the road..................................................................................................
So could you make me a list to perform this conversion? I'm thinking of getting a ga16de from the scrap for $300 CAD low mileage! So from what I've seen the main thing you had to do was modify the engine mounts. Do you have to upgrade suspension/brakes/rad ? I'm probably going to keep the fuel injectors that come with the lump though. So obviously the fuel system is going to have to be modded. Wiring is obviously going to be different as well as well as the driveshafts, which you pointed out too... Any tips or comments?
I live in Canada... It'll be twice that for shipping I bet :( Give me an approx weight of the car and I'll go get some quotes lol..
'Txt speak' is not allowed on the MSC. Please don't be so lazy.
hi mate are those rescent pics of the car?
would u with draw it 4 150??
there the same pics as posted up on here,,condition is still excellent as its been locked away in my garage since last september dry stored and now i need my garage back for my k11 gtir project
price it will go for what ever it makes over the reserve price of £155
hey dude,i hve a k10 and i wana do the conversion ga16ds,how did u uprated your suspension,wot shock absorber have you used?and hve u chnged ur hubs to sunny ones?wot bike carb have you used?
