K10 cant get it to run correctly!
AH.K10
K10/K11
I got another engine to use while i am rebuilding my other one. I have just installed it with a home made exhaust manifold (just manifold and not full system is installed) and lightened fly wheel and it will not idle. I have played with the idle and its only when i turn the idle screw almost all the way in that it runs and idles but when it first starts its reving sooo high and a bit rough. I have set the dizzy roughly in the middle. The only thing that is missing is a condensor from the alternator as it broke.
What do you think?
and you,ve used the original carb ? (the capacitor on the alt is just for radio interferance reasons iirc)
I found the problem.... it was me!!
In a rush connected the dizzy up incorrectly leaving a hose off on the inlet manifold so it was an airleak! all sorted :) Simple stuff just overlooked...
