moleymolo Sep 5, 2009 #1 As the title, anyone make a set? doesn't have to be long, but around 45mm Diameter input to whatever size the intake is (if you get me). Looking to put twin Weber 45's onto them.
A Alienfish360 Awesome Dawson Sep 5, 2009 #2 What are you going to do about the fuelling and ignition timing?
OP OP moleymolo Sep 7, 2009 #3 Doesn't matter about that for the moment. I'm mainly just after an Intake manifold with intakes for each cylinder rather than 4 into 1.
Low Rider Poindexter Founding Member Moderator Club Member Sep 7, 2009 #4 You'll more than likely have to custom build your own.......or maybe k6pfs can help you out with a set of bike carbs if you want to go down that route.
K k6pfs Ex. Club Member Sep 9, 2009 #5 moleymolo said: As the title, anyone make a set? doesn't have to be long, but around 45mm Diameter input to whatever size the intake is (if you get me). Looking to put twin Weber 45's onto them. Click to expand... Hi take a look at my blog, I might be able to help.
superls K10 Tuner Sep 10, 2009 #6 I can make up a set but not immediately, ive custom made a few in the past.
