Instrument cluster or speed sensor?
Hey guys,
My speedometer isn't working, is there a way to test if its the cluster that is bust or the sensor? I've run an ODB 2 test with no codes.
2002 micra k11 - 1 litre // CG10DE
You can check sensor with multimeter will try and post instructions if I remember this version sensor is connected to ecu then from ecu to instrument
Before you remove speed sensor check battery isn’t on way out can cause fluctuations
If ok remove sensor held by 10mm screw/bolt You may need to slightly twist sensor to remove it
Disconnect plug now Check speedo by using a multimeter set at ac across two terminals in Block if you turn speedo cog by hand it should show a reading (there is a you tube video showing how to do this not sure if it’s your version of Micra) hope this helps
