you going to be changing it to manual?
If Ed or someone can sort me a box out etc...
ok will do need to got the head sorted too, i dont know if its linked or this may be the problem all a long but every single plug i took out had a cracked ceramic?
#steve
Ok had a really busy (by that meaning also expensive) week, been making gaskets for the ST as i had to strip the engine down, had all the head faced up, valves reground polished head and also ordered a PROPER head gasket, still looking for a manual gearbox but dont exactly know what gearbox i should put in, weather it would be a prefacelift k11 box or if they did the ST in a manual? and look for an original box with an LSD?
well that's all the progress for now, just waiting for the new engine block from ED, but have pleanty to do in the mean time
Steve
No I never got a St box of barry. I nearly did but never finalised it.
Quick update:
Block came today cheers Ed!, i didnt know couriers were up at 7:55am!!
looks ok, should get everything skimmed up sometime next week and still got a lot of new gaskets to make.
Steve said he wasnt in a rush then kept asking when it would arrive hahaha Glad you got it all ok !
CG gaskets are 72mm (1mm bigger than the cyl bore) if thats any indication
ah ok, cheers frank, im going to get a gasket made anyway, should be made of better stuff than stock
Thats true, but mine has done fine the last nearly 3years
Quick question for Baz and / or Ed:
as above i have been recommended the figaro gasket by ferriday engineering but dont know what you think about this. I can understand why Ed had a custom head gasket with the power he was running his St at but considering im not planning to go above 1.2 bar i just wanted to see what everyone thought of this as i obviously dont want this to happen again, but is it worth £167 for a new gasket?
Steve
Why do we have to go over the same things over and over Steve?It's up to you if you want the uprated, personally I think you have nothing to lose using the fig gasket,as I said time and time again mine is 151hp running just under 1.2 bar(1.18 is the peak) and is running a standard st gasket the fig one is the same oem quality and if your happy with the dimensions and as I see above you seem to be then go for it.
If the engine is built properly all torques checked and rechecked it should be fine
Baz
btw, not given out(Y)
i just dont want to have to spend the same amount again if this was the original cause
I don't think it was to be honest Steve
ok cheers i just wasnt too sure if you lot thought this could have been it, i will proceed with the figaro gasket. getting it back together slowly now
cheers
Steve
